Wipro Limited
Last activity: 10 Nov 2016 13:49 EST
Border was missing
I am using a simple layout and in it i used a row repeating grid. But some how the border was missing at the end.
Anyone knows what the cause for this. Please reply.
Naresh K.
***Updated by moderator: Lochan to add Category***
Hello Naresh,
Thanks for sharing the attachment. From the provided file(Column border missing.docx), I see that Container format is set to None. Can you try setting the Container format to Other > Nested.
Also, does changing the width of content [from Pixel(Fit Content) to 100% or Fixed width] help?
If above does not help, provide the screenshot showing the configuration made for other layouts with Admin column that shows border correctly.
Rincy
Hello Naresh,
Thanks for posting your query in PSC. :)
Could you provide below information:
- Pega version used
- Screenshot of the layout and repeat grid. This is to view if you have set any inline cell style to these UI components.
- Screenshot of the skin(if it customized)
Rincy
Hi Naresh,
You can try adding the border in the format used (under Trees & Grids component). You can specify them by adding in the border tab.
Sample: - In the container format you are using say Nested. Under body tab, Border -> Set the border style as appropriate.
Best Regards,
Mounika
Wipro Limited
Hi I didn't see Nested in the skin rule under Trees & Grid component Mounika.
However, i modified border settings of "Default" and tested.. the issue not resolved.
The issue is:
Hi Naresh,
From the above screenshot, we can ee that the border style is none. Can you try modifying and check ?
Also, you can try to identify the styles with F12 / Chrome debugger.
Best Regards,
Mounika
Hi Naresh,
Could you please provide the screenshots of the grid and the configuration so that we can try the same usecase at our end and then work on a solution?
Gisela
Wipro Limited
Sure. I will upload the screenshots by Monday monring. I will be in transit this week. Thanks!
Wipro Limited
Hi Gisela,
Attached the document for your reference.
Hello Naresh,
Rincy
Wipro Limited
It works.. Container format to Other > Nested.
Thanks RINCYRAPPAI ... :)
