Switching Portal in CPMi
Earlier from CPMi Portal user was able to switch between portal provided multiple access group are added to the user profile. But after upgrade CPMi don't provide these option of switching portal. User had to update the profile everytime to get to the required portal landing page. Is there any efficient work around.
You can still switch between multiple portals in same Access Group. However, if you want to access portals in different access groups then you need to switch the application.
