Last activity: 30 Sep 2022 11:13 EDT
Robotics Tip of the day: Test an automation and leave the application open
Tip #4: The new Test feature lets you leave your applications running after the test completes.
Use the Test feature to execute an automation. Notice that while you are executing the test, you can see the matching status for the application controls that are used. After the test completes, you can leave the application open and test another automation.
In this example, the Login automation is tested first and the application is left open. Next, the Customer search automation is tested.
Note: Click here to see the latest Tip of the Day and a list of all prior tips.
