Web Application is not responding accordingly using Pega Robot Runtime 22.1
I have an automation that uses web application. It functions as expected when running the automation using Pega Robot Studio 22.1. However, when I am running the automation using Pega Robot Runtime 22.1, the web application is not responding accordingly.
Scenario in Pega Robot Runtime 22.1: When the automation is started, it will open the web application, the automation is expected to log in, however, given that there is already a long pause, the automation was not able to see the object even the web application is already opened. This is not happening in Pega Robot Studio 22.1.
What is the possible reason for this? What is the possible solution to fix this?
@ThomasSasnettI already resolved the issue. I re-interrogated the web application and disabled the Xray Vision and it works.
