RAP import is failing in 7.1.8
we are importing RAP file from 7.1.8 single schema to 7.1.8 split schema environment. But the import failed with following error. Any resolution/work around for that?
2015-11-23 12:17:11,604 [PRPCWorkManager : 18] [ STANDARD] [ ] [Appointment:01.01.01] (ga_importexport_pximportexport) ERROR zkycyv7 - ImportArchive: Encountered the following error: A problem occurred.
com.pega.pegarules.pub.PRException: A problem occurred.
at com.pega.pegarules.deploy.internal.loaders.SaverLoader.importContents(SaverLoader.java:539)
at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:889)
at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:762)
at com.pega.pegarules.deploy.internal.util.ImportImpl.importArchive(ImportImpl.java:670)
at com.pega.pegarules.deploy.internal.util.ImportImpl.importPegaArchive(ImportImpl.java:739)
at com.pega.pegarules.deploy.internal.archive.PegaArchiveAbstract.doImport(PegaArchiveAbstract.java:362)
at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.pxImportArchive07_10_17(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:142)
at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.invoke(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:84)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8954)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_importexport_pximportexport.pxImportArchive(pega_importexport_pximportexport.java:281)
at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.step8_circum0(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:879)
at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.perform(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:207)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:453)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:257)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:320)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.pegarules.session.internal.async.Agent.runBatchTask(Agent.java:815)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:230)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:238)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:269)
at java.security.AccessController.doPrivileged(AccessController.java:273)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:769)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:159)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1660)
Caused by:
java.lang.RuntimeException: caught exception while expanding property pxWarningsToDisplay on page .pxWarnings(1)
at com.pega.pegarules.data.internal.clipboard.DirectStreamContainerV7.expandToProperty(DirectStreamContainerV7.java:791)
at com.pega.pegarules.data.internal.clipboard.DirectStreamContainerV7.expandAllToProperties(DirectStreamContainerV7.java:536)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.expandAll(ClipboardPageImpl.java:1146)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.expandAll(ClipboardPageImpl.java:1140)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.expandAll(ClipboardPageImpl.java:1136)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.values(ClipboardPageImpl.java:4960)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.values(ClipboardPageImpl.java:4976)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7$PageSection.addPage(DirectStreamEncoderV7.java:1615)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7$PageSection.addPageNew(DirectStreamEncoderV7.java:785)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7$PageListSection.addPageList(DirectStreamEncoderV7.java:3432)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7$PageSection.addProperty(DirectStreamEncoderV7.java:2179)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7$PageSection.addPageNew(DirectStreamEncoderV7.java:826)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoderV7.encode(DirectStreamEncoderV7.java:382)
at com.pega.pegarules.data.internal.clipboard.StorageStreamCommonImpl.encode(StorageStreamCommonImpl.java:844)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getStreamForm(ClipboardPageImpl.java:3831)
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.getStreamFormOfPage(PageDatabaseMapperImpl.java:1452)
at com.pega.pegarules.data.internal.access.DatabaseImpl.preprocessInstancesBeforeCriticalCommitSection(DatabaseImpl.java:3109)
at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2636)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2308)
at com.pega.pegarules.data.internal.access.DatabaseImpl.commit(DatabaseImpl.java:2047)
at com.pega.pegarules.deploy.internal.loaders.SaverLoader.issueCommit(SaverLoader.java:831)
at com.pega.pegarules.deploy.internal.loaders.SaverLoader.importContents(SaverLoader.java:263)
... 50 more
Caused by:
com.pega.pegarules.pub.clipboard.WrongModeException: The property .pxWarningsToDisplay was of mode Page List while com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.setValueOverride(Object) was expecting a String or Page mode. Details: (none)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.setValueOverride(ClipboardPropertyImpl.java:3911)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.setValueOverride(ClipboardPropertyImpl.java:3787)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.adopt(ClipboardPropertyImpl.java:4521)
at com.pega.pegarules.data.internal.clipboard.DirectStreamContainerV7.expandToProperty(DirectStreamContainerV7.java:717)
... 71 more
