Last activity: 6 Nov 2015 15:45 EST
IAC - How to Associate Skin to Gadget in PEGA 7.1.8
IAC gadget is not inheriting application skin automatically. I have tried by passing skin rule but dont see any change to Harness style. By default IAC gagets are taking pyenduser skin rule. I have tried as mentioned in PDN but it is not working. Any help is appreciated.
could you please try adding the attribute pzSkinName:"myAppSkin" for PegaA_params
It is working with {pzSkinName:"Appskin"}. Thanks for your help.
Synechron Inc
Its not working for me even after giving the parameter. Not sure what I am missing. Any thoughts?
are running on 7.1.8 ? if you have and older version, the parameter name to pass might be different
Synechron Inc
Yes we are using 7.1.8.
As of now I am passing it like this
PegaA_params={UserIdentifier:"XXXX",Password:"XXXX",pzSkinName:"pyEndUser71"}
pyEndUser71 is our skin name
posted a doc that explain how to troubleshoot the issue .
I have the correct pzSkinName but my skin still doesn’t show up…
When the correct skin is passed through the pzSkinName parameter, then it is probably a problem with the user profile. Does the profile of the user have the portal that’s using the skin as the default user portal?
For example, using the example above, the MKTProfileUser only has access to the following application: PegaSFA_NBAM
In order for the MKTProfileUser to pick up the correct skin, the default portal for the user should be the one that contains the skin the application should load:
Synechron Inc
Thanks Richard for the post. Unfortunately my widget is still not picking the correct skin. But its picking some skin thats not source nor mine. Strange
