Issue
When a user opens an Insight from a landing page or dashboard, the error "Table data took too long to fetch" is displayed, and the table either loads no data or loads only partial data.
Symptoms and Impact
- Data fails to load.
- Query execution times exceed 50 seconds, surpassing the default 10-second timeout.
The problem is most pronounced on tables with a large number of rows (hundreds of thousands or more).
Chart-type Insights expose a "" button when the initial 10-second threshold is exceeded, but table-type Insights do not invoke the extended-timeout retry path and fail immediately.
Steps to Reproduce
- Create an Insight on a class that is backed by a large database table (for example, Assign-Workbasket).
- Configure one or more filter conditions on columns such as assigned Operator ID or Assignment Status.
- Open the Insight from a landing page or dashboard while logged in as a user.
- Result: The browser network log shows the data-fetch request timing out after approximately 10 seconds.
- Observe the error message displayed in the Insight widget.
- Result: The error "Table data took too long to fetch" is shown. Data is absent or partially loaded.
Root Cause
Pega Platform™ applies ignoreCase=true by default on Insight filter requests to support case-insensitive user input. At the database layer this causes the platform to wrap the left-hand side of each filter condition in a SQL UPPER() function (for example, UPPER("PC0"."pxassignedoperatorid") = ?).
Because the UPPER() expression does not match any standard index on the column, the database engine cannot use existing indexes and resorts to a full table scan. On large tables, query execution can exceed 50 seconds, consistently surpassing the platform's 10-second synchronous fetch timeout for Insights. A secondary gap exists: the useExtendedTimeout retry mechanism (which allows up to 40 additional seconds) is not invoked for table-type Insights when the initial timeout is exceeded, unlike chart-type Insights which expose a "Try again" button.
Solution
The UPPER() behavior is expected product behavior. The absence of an option to selectively disable it or of a function-based index created out of the box is a documented product feature gap which is planned to be addressed in a future Pega Platform release.
The following steps resolve or mitigate the issue.
Pega Cloud deployments
The preferred resolution is to create a function-based index on the affected table so that the database engine can satisfy the UPPER()-wrapped query without performing a full table scan.
Raise a Cloud Change Request for the Cloud DBA team to create appropriate function-based indexes for those columns. Validate the affected Insights after index creation.
On-Prem users must work with their DBA and apply appropriate indexing based on the property used.
Steps to identify and remediate additional affected Insights:
- Enable DB Query events in Pega Tracer and reproduce the timeout to capture the exact SQL query and bind variables.
- From the captured query, identify every column to which UPPER() is applied (for example, pxassignedoperatorid, pyassignmentstatus).
- Create a function-based index for each affected column. For example, on the pc_assign_workbasket table, an index keyed on UPPER(pxassignedoperatorid) allows the database engine to use the index even when the column is wrapped in UPPER().
- After the change, reopen the affected Insights and confirm that data loads without error.
Repeat steps 1–4 for each additional Insight that triggers the same timeout.
Local Change
If creating a function-based index is not immediately feasible, you can remove the case-insensitive behavior from the Insight query for the affected filter fields. When the UPPER() function is no longer applied to a filtered column, the database engine can use the standard index on that column, and query performance typically returns to an acceptable level. Note that this makes the filter case-sensitive; verify that the filtering behavior still meets business requirements before applying this change in production.
