All updates indicated below will be implemented within Pega platform for 26.1.1 release and, if Bug set indicates "yes" then it will be included in patch releases to previous release lines in 24.2 and 25.1. Design theme is indicated for impact, i.e., constellation versus traditional UI. Each item below can also be found in the attached xlsx document.
Update: AI Agent- suggestion card accessible label
Release: 26.1.1
Bug set:
Design theme: Constellation
Summary: The suggestion card accessible label now comes from the card heading when present, with row-header fallback when no heading exists. Constellation design system.
Update: Dashboard Edit button now has a descriptive label
Release: 26.1.1
Bug set:
Summary: Added aria label 'Edit {dashboard name}'. Constellation design system.
Update: Create button now respond when navigation is collapsed
Release: 26.1.1
Bug set:
Summary: Implemented Enter-key handling for collapsed navigation create action flow. Constellation design system.
Update: Rich text editor updated to navigate past bold in toolbar
Release: 26.1.1
Bug set:
Summary: Fixed. Able to arrow through toolbar with new TipTap RTE. Constellation design system.
Update: No indication of appearance of refresh banner for screen reader
Release: 26.1.1
Bug set:
Summary: Added live announcement for refresh banner appearance. Constellation design system.
Update: Unclear Accessible Name for Navigation Toggle Button
Release: 26.1.1
Bug set:
Summary: Set static aria-label to 'Navigation panel' and removed tooltip naming conflict from accessibility target. Constellation design system.
Update: Accessibility issue during 200% zoom of a modal dialog filters
Release: 26.1.1
Bug set: Yes
Design theme: Traditional design system
Summary: Modal dialog accessibility corrected for zoom. Focus now remains within the modal dialog when navigating controls at high zoom levels. Traditional design system.
Update: Anypicker clear icon aria-label removed after refresh
Release: 26.1.1
Bug set: Yes
Summary: Updated: accessibility labels maintained after section refresh for AnyPicker controls. Traditional design system.
Update: App name no longer disappearing for smaller screens
Release: 26.1.1
Bug set:
Summary: Ensured app name remains visible on small viewport widths with responsive top-bar fallback behavior. Constellation design system.
Update: Blank values in text field are no longer empty
Release: 26.1.1
Bug set: Yes
Summary: Updated: table empty value display restored to -- while preserving accessibility compliance. Traditional design system.
Update: Blended login prompt overshadowed by masking layer
Release: 26.1.1
Bug set: Yes
Summary: Updated: blended UI login modal visibility restored during token-expiration scenarios. Constellation design system.
Update: PerformHarness footer aria issue fixed
Release: 26.1.1
Bug set: Yes
Summary: Harness footer accessibility corrected by removing incorrect footer aria-label persistence. Traditional design system.
Update: Focus lost on escape from date picker dialog
Release: 26.1.1
Bug set: Yes
Summary: Updated: focus restored to date picker calendar icon after escape key closure. Traditional design system.
Update: Hierarchical table link visible focus increased padding
Release: 26.1.1
Bug set: Yes
Summary: When tab focus was applied to link controls in hierarchical tables, a solid outline visible focus indicator was appearing with insufficient padding around the content that caused values to appear cramped. This has been resolved by adjusting the outline spacing and padding properties to improve accessibility and visual appearance for focused link elements in hierarchical tables. Traditional design system.
Update: Insight column filter showing two vertical scroll bars
Release: 26.1.1
Bug set:
Summary: Insight column filter scrollbar display corrected by removing nested/double scrolling behavior. Constellation design system.
Update: Anypicker had role progress which is invalid
Release: 26.1.1
Bug set: Yes
Summary: Aria role corrected for anypicker t to meet aria guidance. Traditional design system.
Update: Keyboard focus no longer moves to header controls that are not visible
Release: 26.1.1
Bug set: Yes
Summary: Keyboard navigation visibility corrected for hidden/inactive header controls. Traditional design system.
Update: Left hand panel tabs not narrating correctly
Release: 26.1.1
Bug set:
Summary: When using JAWS to navigate through the tabs on the left panel, the jaws narration is saying to use the left and right arrow keys to navigate when it should be the up and down keys. this has been corrected. Traditional design system.
Update: Nested sub menu scroll issue
Release: 26.1.1
Bug set: Yes
Summary: Nested menu navigation improved to keep all options reachable and maintain correct tabindex behavior. Traditional design system.
Update: Newly added widgets to utility panel have empty tooltips
Release: 26.1.1
Bug set:
Summary: Fixed empty tooltips by mapping each widget to localized label values with fallback behavior. Constellation design system.
Update: Widget label in ViewMetadata
Release: 26.1.1
Bug set:
Summary: Removed label from widget VMD output for newly created widgets. Constellation design system.
Update: No focus ring in date range fields
Release: 26.1.1
Bug set:
Summary: Corrected focus indicator rendering for date range fields without inner labels. Constellation design system.
Update: Overlay modal screen reader caption announcement
Release: 26.1.1
Bug set: Yes
Summary: Screen reader announcements are now consistent between modal and overlay modal caption flows. Traditional design system.
Update: Read medium-format dates in expanded readable format
Release: 26.1.1
Bug set:
Summary: Date display accessibility improved by using expanded readable date values and semantic time/abbr tags. Constellation design system.
Update: RTE image handling tooltip issue
Release: 26.1.1
Bug set:
Summary: Created separate accessible and standard labels for image action tooltips. Constellation design system.
Update: Success banner dialog keyboard focus accessibility
Release: 26.1.1
Bug set: Yes
Summary: Keyboard navigation improved for success dialogs and close button announcement behavior. Traditional design system.
Update: Table Grid expand/collapse issue when Group By is enabled
Release: 26.1.1
Bug set: Yes
Summary: Table group expand/collapse functionality restored with corrected accessibility state handling. Traditional design system.
Update: Textarea focus getting lost when scrolling within textarea
Release: 26.1.1
Bug set: Yes
Summary: Updated: textarea focus restored during zoomed scrolling and viewport shift scenarios. Constellation design system.
Update: Visibility condition not working on zoom
Release: 26.1.1
Bug set: Yes
Summary: Visibility condition rendering corrected for summary panel tabs under zoom/collapse scenarios. Traditional design system.
Update: Rule and custom condition dropdown not displayed
Release: 26.1.1
Bug set:
Summary: Upgraded atlasmap version and merged fix PRs across relevant branches. Constellation design system.
