All incidents addressed will be implemented within the Pega platform Infinity ’25.1.2 patch release and will also be in subsequent releases. Where configuration is required to adopt the fix, this will be indicated within the specific item below.
Each issue addressed is provided below, along with the original spreadsheet of these issues attached at the bottom.
Search results remain after moving cursor away in UIKit application header
Resovled in: 25.1.2, 26.1
INC source: INC-C51543
Design Theme: UIKit
When performing a search in end user UIKit portal app headers, results will remain on the UI when moving the cursor away.
Confirmation provided when following or unfollowing a case
Resolved in: 25.1.2
INC source: INC-C11245
Design Theme: Constellation
When following or unfollowing a work object, a toast message will appear at the bottom of the screen confirming the user's decision. This toast message is announced by screen readers.
Required data reference tables are have properly associated validation messages
Resolved in: 25.1.2, 26.1
INC source: INC-C45944
Data reference fields displayed as tables and configured with required validation will have correct association between the grid and inline error message when no value is selected.
Dialog title is correctly labeled for pyFlexModalTemplate
Design Theme: UIKit, Theme Cosmos
The aria-labelledby reference has been updated to contain a valid ID for dialog elements introduced by pyFlexModalTemplate.
Expand/Collapse dynamic layout headings provide visible focus indicator when summary panel is collapsed
INC source: INC-C59383
Design Theme: Theme Cosmos
In Cosmos applications where the summary panel of a work object is collapsed, expand/collapse dynamic layout headings provide a visible focus indicator.
NoID harness error message is announced by screen reader
Resolved in: 24.2.4, 25.1.2, 26.1
INC source: INC-C58145
When the NoID harness/section is displayed on screen due to a processing error, the error message contents will be announced by screen readers.
Focus does not move to generic container element in Fields overlay
INC source: INC-C54311
In the Fields overlay launched from the toolbar of optimized tables, keyboard focus will no longer be able to reach a generic div element that contains the overlay contents.
Required field validation does not automatically trigger when adding new row to table
INC source: INC-C51009
When adding a new row to an editable table in Constellation where the first column contains a required field, validation will not immediately trigger when focus is placed on the first cell of the new row.
Keyboard focus is no longer trapped on field configured with smart tip after validation
INC source: INC-C49366
When validation occurs in a form on submit and keyboard focus is placed on an error field configured with a Smart tip, keyboard focus will no longer become trapped on that field and can move through interactive elements as expected.
Programmatic label provided for action column headers
INC source: INC-C48743
In tables containing a right-most column used for deleting rows or providing a menu for various actions to take on the row, the column header now contains an aria-label of "Delete" or "Actions", respectively.
Focus cycling corrected in modal dialogs containing multiple tables
INC source: INC-C54972
In modal dialogs configured to contain one or more tables and the default flow action buttons hidden, keyboard navigation with Tab key allows users to cycle through all interactive elements in the dialog as expected.
Optimized tables consistently initialize the first row as the default selected row
INC source: INC-C41144
In screens containing multiple optimized tables, the selected row - indicated by a different background color than other rows - will consistently be the first data row of the table rather than a random row within the table.
Tooltip present for delete icon in table Sort overlay
INC source: INC-C43413
Delete icons for sorts applied to a table in the Sorting overlay now present a visible tooltip on mouse hover and keyboard focus.
Completed steps in stage overlays relay status to screen readers
INC source: INC-C32532
In the stage overlay for a given stage within a case lifecycle, completed steps with adjacent green checkmarks will relay the status "Completed" to screen reader users.
Focus remains on follow button in case header when activated
Resolved in: 24.1.4, 24.2.4, 25.1.2, 26.1
INC source: INC-C32635
When activating the follow button in the case header of a work object, keyboard focus remains on the button
Page link pagination for non-optimized tables provides a visible focus indicator
INC source: INC-C38112
The pagination format which uses page links (1 2 3 Next) in non-optimized tables has been updated to provide a visible focus indicator when navigating with keyboard.
Focus can cycle back to close icon in header of dirty form dialog
INC source: INC-C18782
When the DSS "ModalDialogXIconFocus" is set to true, keyboard focus is able to cycle back to the close icon in the header of the dirty form confirm dialog when navigating using the Tab key.
DSS added to allow initial focus on close icon in pzModalTemplate
INC source: INC-C25264
The Dynamic system setting "ModalDialogXIconFocus" has been added, which allows authors to designate if initial keyboard focus should be placed on the close icon in the header of local actions launched using pzModalTemplate.
Smart info icon for questions is accessible by keyboard
INC source: INC-B51876
The smart info icon that can be configured to appear adjacent to question fields has been updated to allow keyoard focus and activation. It has the semantic role of button, a programmatic label, and visible focus indicator.
Expand/collapse buttons in Summary reports have button role
INC source: INC-C12345
The expand/collapse caret icons for each expandable row in a summary report now has the semantic role of button rather than link.
Case history dialog hides iframe data to assistive technology
Resolved in: 24.1.4, 25.1.2, 26.1
INC source: INC-C45593
The iframe data previously present within the Case narrative tab of the case history dialog has now been hidden to assistive technologies as it was not relevant to case details.
Visible focus returns to grid cell that launched modal dialog
INC source: INC-C31047 INC-C38909
When dismissing a dialog launched from an interactive element in a grid cell in an optimized table, a visible focus indicator will be present on the grid cell to indicate where focus returned to.
Help icon with overlay on focus displays tooltips containing multiple lines
INC source: INC-C47263
When the helper text option "help icon with overlay on focus" is used on a form control and sourced by a field value containing two or more lines, the tooltip will display as expected at runtime.
Calendar button retains correct label when certain characters included in date label
INC source: INC-C38028
When the label of a date time field includes an apostrophe or quotation mark, the label of its respective calendar icon no longer truncates at the location of the apostrophe/quotation mark.
