All incidents addressed will be implemented within the Pega platform from Infinity '23 up to Infinity ’24.1.4 and will also be in subsequent releases. All Pega customers and applications on the platform will immediately receive these enhancements upon upgrade. Where configuration is required to adopt the fix, this will be indicated within the specific item below.
Each issue addressed is provided below, along with the original spreadsheet of these issues attached at the bottom.
Focus remains on follow button in case header when activated
Resolved in: 24.1.4, 24.2.4, 25.1.2, 26.1
INC source: INC-C32635
Design Theme: UIKit, Theme Cosmos
When activating the follow button in the case header of a work object, keyboard focus remains on the button.
Page link pagination for non-optimizes tables provides a visible focus indicator
INC source: INC-C38112
The pagination format which uses page links (1 2 3 Next) in non-optimized tables has been updated to provide a visible focus indicator when navigating with keyboard.
Focus can cycle back to close icon in header of dirty form dialog
INC source: INC-C18782
When the DSS "ModalDialogXIconFocus" is set to true, keyboard focus is able to cycle back to the close icon in the header of the dirty form confirm dialog when navigating using the Tab key.
DSS added to allow initial focus on close icon in pzModalTemplate
INC source: INC-C25264
The Dynamic system setting "ModalDialogXIconFocus" has been added, which allows authors to designate if initial keyboard focus should be placed on the close icon in the header of local actions launched using pzModalTemplate.
Smart info icon for questions is accessible by keyboard
INC source: INC-B51876
The smart info icon that can be configured to appear adjacent to question fields has been updated to allow keyoard focus and activation. It has the semantic role of button, a programmatic label, and visible focus indicator.
Expand/collapse buttons in Summary reports have button role
INC source: INC-C12345
The expand/collapse caret icons for each expandable row in a summary report now has the semantic role of button rather than link.
Case history dialog hides iframe data to assistive technology
Resolved in: 24.1.4, 26.1
INC source: INC-C45593
The iframe data previously present within the Case narrative tab of the case history dialog has now been hidden to assistive technologies as it was not relevant to case details.
Visible focus returns to grid cell that launched modal dialog
INC source: INC-C31047
INC-C38909
When dismissing a dialog launched from an interactive element in a grid cell in an optimized table, a visible focus indicator will be present on the grid cell to indicate where focus returned to.
Single-item lists removed from work objects in the Recents panel
Resolved in: 24.1.4, 25.1.1, 26.1
INC source: INC-C9516
Design Theme: Constellation
Items in Recents that contain metadata within the item, such as the case ID for a case listed, no longer generates list markup containing only 1 item.
Stage links in case view relay their status to screen readers
Resolved in: 24.1.4, 24.2.2, 25
INC source: INC-C9640
Design Theme: UIKit
Screen reader users navigating through stage links in a work object in UIKit will hear the status of the stage announced as supplemental description text, that being Past, Active, or Future.
Help icon with overlay on focus displays tooltips containing multiple lines
INC source: INC-C47263
When the helper text option "help icon with overlay on focus" is used on a form control and sourced by a field value containing two or more lines, the tooltip will display as expected at runtime.
Calendar button retains correct label when certain characters included in date label
INC source: INC-C38028
When the label of a date time field includes an apostrophe or quotation mark, the label of its respective calendar icon no longer truncates at the location of the apostrophe/quotation mark.
Aria-multiselectable attribute moved from combobox to listbox
Resolved in: 23.1.5, 24.1.4, 24.2.3, 25
INC source: INC-C24882
For multiselect controls, the aria-multiselectable attribute has been moved from the combobox input element to the listbox of options to adhere to standard practice.
Close icon in pzModalTemplate activates on mouse up
Resolved in: 24.1.4, 24.2.3, 25.1.1
INC source: INC-C28836
To prevent accidental or erroneous input, the event handler for the close icon in pzModalTemplate now uses mouse up rather than mouse down.
Buttons launching local actions have incorrect attribute removed
Resolved in: 24.1.4, 24.2.3, 25.1.1, 26.1
INC source: INC-C38186
Buttons that launch local actions in modal dialogs and overlays no longer have the incorrect aria-expanded attribute.
Focus remains on save button when activated in screen flow
INC source: INC-C35762
Design Theme: Theme Cosmos
When activating the Save button in a work object that makes use of a screen flow to display assignments, keyboard focus will remain on the save button.
Report table headers have visible focus indicators
INC source: INC-C35183
Interactive elements in report table headers in the Reports browser will now provide a visible focus indicator when navigating through interactive elements with keyboard.
Autocomplete as combobox has accessible clear button
INC source: INC-C30858
Autocomplete controls configured as combobox will display a clear, or "X" button in at the end of the input region to clear the current selection. This button can be focused and activated with the keyboard.
Session timer dialog has corrected label
INC source: INC-C28719
The sesion timer dialog now has a meaningful label that reflects the visible title of the dialog.
Case summary panel expand/collapse button has programmatic label
INC source: INC-C32722
The Expand/Collapse button for the case summary panel in a work object in Cosmos applications now always has a programmatic label.
Expand/Collapse icon in Summary report tables is focusable with keyboard
INC source: INC-C41181
Expand/Collapse icons in Summary report tables can be focused and interacted with using the keyboard.
Help icon tooltip display when sourced by Field value with more than one line
INC source: INC-C11292
The Help icon with overlay on focus will correctly display the full tooltip value when sourced by a Field Value containing 2 or more lines of text.
Close icon in overlays provides visible focus indicator and supports keyboard action
INC source: INC-C22554
The close icon at the top of overlays that have "Disable clickaway" configured now provide a visible focus indicator and allow users to activate it using the keyboard.
Notifications in the left panel have incorrect role removed
INC source: INC-C33867
The incorrect role of "listbox" has been removed from notification items in the left navigation panel of Cosmos, and allows screen readers to hear all the notification details announced correctly when navigating with arrow keys.
Focus can be brought back into non-optimized table rows when editable
INC source: INC-C4770
When tabbing out of a non-optimized table that has inline editing enabled, focus is able to return to the rows and fields within the table.
Inline error messages announced by screen readers when Smart Tip is also configured
INC source: INC-C21062
On required fields that also have a Smart Tip action configured, validation error messages are announced by screen readers when they appear.
Server-side validation focus behavior does not conflict with pySetFocusOnAssignmentTitle
INC source: INC-C22254
When server-side validation is triggered on submit and the When rule pySetFocusonAssignmentTitle is set to True, focus will now correctly be placed on the field with an error rather than focusing the assignment title.
Focus returns to gear icon in Followers widget when closing dialog
Resolved in: 23.1.5, 24.1.4, 24.2.3, 25.1.1, 26.1
INC source: INC-A29326
When dismissing the "Followers" dialog launched from the Utilities panel widget, focus will return to the gear icon that launched the dialog.
Review harness "To do" heading is heading level 2
INC source: INC-C33676
The "To do" heading in the Review harness of a work object is now heading level 2 to align with the existing page hierarchy and default heading level of assignment titles in the Perform harness.
Session timer behaves as a modal dialog
INC source: INC-C26776
When the session timer dialog appears in the end user portal to let users know of an impending logoff, content behind the dialog can not be accessed until the user explicitly dismisses the dialog. The close "X" icon will display correctly in the session timer dialog if there is another modal dialog already open when it appears.
Cell border remains visible when editing an inline field in a table
INC source: INC-C25837
Cell borders in a table will remain visible when focus is brought into a editable field within the cell. This is applicable to master-detail editing of non-optimized tables.
Fields with corrected validation within a table flow action have correct styles
INC source: INC-C31140
Fields that triggered a validation error in a flow action launched from a table will have their label color changed back to default rather than remain red once the error is corrected.
Header buttons in Report Editor meets contrast requirements
INC source: INC-C27086
Buttons in the header of the Report Editor screen have had their colors updated to meet contrast requirements with the background.
Error list structure is not overridden by alert role
INC source: INC-C19790
The error list structure that appears when server-side validation occurs now maintains its list structure. The role of alert used for live screen reader announcements has been moved off the list and onto a parent container element.
Expand button hidden in case hierarchy table when no child case is present
INC source: INC-C14758
Design Theme: UIKit
The caret icon used to expand the case hierarchy is now both visually hidden and hidden to assistive technologies when no child case is present.
Aria-label provided for RTE
INC source: INC-A23056
An aria-label value is provided for Rich Text Editor controls to allow assistive technologies to recognize the configured label of the control.
Padding between radio buttons and their individual labels increased
INC source: INC-C33281
Padding has been increased on radio buttons so that the box shadow focus indicator does not overlap with the respective label text.
Preview button on last Notification item is focusable with keyboard
INC source: INC-C18593
Focus logic has been updated in the RDL used to display Notifications in the Cosmos left panel so that focus can be moved to the Preview button which appears on the very last notification in the list.
Expand icon for summary tables in Cosmos are focusable
INC source: INC-C27311
In a Summary table in the Cosmos report browser, expand/collapse icons for each row are now focusable with keyboard.
Footer elements in the calendar dialog displaying only time have visible focus indicators
INC source: INC-C24373
The Apply and Close buttons in the footer of the calendar overlay displaying only time now have visible keyboard focus indicators.
Screen flow step indicators provides step status in their labels in UIKit
INC source: INC-C19910
Design Theme: UIKit
Screen flow steps in the step indicator will now denote the status of the step (past/current/future) in the programmatic label of each link.
Calendar icon for date dropdowns has updated color contrast
INC source: INC-C19973
Color contrast for the calendar icon that can display next to date controls configured as dropdowns now has an updated color to meet contrast requirements.
Bulk action operation sections begin with semantic <h2>
When using the bulk actions component to Create, Update, and Process work objects, the sections corresponding to each option now begin with a semantic <h2> heading element.
Layout groups maintain structure when selecting Semantic tab layout
INC source: INC-C10206
When selecting the "Semantic tab layout" on a layout group displaying as tabs, the tab contents will no longer become stacked layouts at runtime and will maintain their tab structure.
Days of week listed in calendar dialog have updated color to meet contrast requirements
INC source: INC-C19770
The days of the week listed in the date time control's calendar dialog (i.e. Mon, Tue, Wed) have updated text color to meet contrast requirements.
Anypicker control does not announce multiple times to screen reader
INC source: INC-C16881
Role attributes for the anypicker control and the search results listbox have been updated to prevent the label and role from being announced multiple times by screen reader
Clear icon for selected option in Anypicker has updated label and keyboard functionality
Resolved in: 23.1.5, 24.1.4, 24.2.3, 25, 26.1
INC source: INC-C15899
Clear icons for selected options in the anypicker control have an updated aria-label to reflect its purpose and allow for keyboard activation.
Focus remains in modal dialog when default action buttons are hidden with refresh
INC source: INC-C15007
In scenarios where a modal dialog contains an element that refreshes the section along with removing the default Cancel/Submit action buttons, keyboard focus will still only cycle through elements within the dialog as expected.
Child case overlay contents are interactable with keyboard
INC source: INC-C21248
In a Cosmos work object that has one or more child cases, the related case overlay, which opens through the Case Summary panel, allows users to navigate and interact with the breadcrumb contents within using keyboard.
Chart actions links have contextual aria-labels
INC source: INC-C22627
Report charts displayed on any screen have an associated "Chart Actions" link, which now has an aria-label value containing the associated chart name for better context.
Close icons for selected values in Anypicker control have contextual labels
Close icons for selected values in an Anypicker control now have the aria-label value of "Clear [Selection]"
Decorative icon on Anypicker control hidden to assistive technologies
INC source: INC-C17245
The decorative caret icon present on Anypicker controls, which cannot be focused with keyboard, now has the aria-hidden attribute to prevent assistive technologies from recognizing it.
Layout group tabs remain visible when fullscreen RTE is present in modal dialog
INC source: INC-C11507
When using an RTE in a modal dialog within a layout group, tab labels will remain visible on the UI when entering fullscreen mode on the RTE.
Image controls that launch a Smart Info will not re-open the Smart Info upon activating close
INC source: INC-C18767
Image controls that are configured with a Smart Info action set will no longer quickly re-open the Smart Info after the user dismisses it using the close button. This was occurring due to an incorrect event listener on the close button.
Submenu items in left navigation panel have visible focus indicators
Resolved in: 23.1.5, 24.1.4, 24.2.2, 25
INC source: INC-C10615
Design Theme: UIKit
Submenu items under Following, Recent, and Team Members now have visible keyboard focus indicators in the UIKit left navigation panel
Operator button menu has updated label to include operator name and role
INC source: INC-C14334
The operator menu button present in the left navigation panel of Cosmos applications has had its programmatic label updated to include both the operator name and button label as "[Operator name] Operator menu".
Tooltip helper text option added for radio button controls
INC source: INC-C19950
The tooltip helper text configuration option is now available for radio button controls.
Gear icon in notifications has programmatic label
INC source: INC-C15345
Design Theme: UIKit
The gear icon corresponding to notifications listed in the Notifications overlay in the header of UIKit applications has a programatic label.
OK button can be accessd using keyboard on Logoff timer warning dialog
INC source: INC-C15432
Keyboard users are able to access the "OK" button present in the Logoff timer warning modal dialog.
Notification counter menu item relays count to screen readers in UIKit applications
INC source: INC-C14769
Design Theme: UIKit
The Notifications button in the header of UIKit applications will relay the notification count, which also displays visibly as an icon, back to screen readers when focused with keyboard.
Notification counter menu item relays count to screen readers in Cosmos applications
INC source: INC-C17307
The Notifications menu item in the Cosmos left navigation panel will relay the notification count, which also displays visibly as an icon, back to screen readers when focused with keyboard.
Grid navigation corrected in hybrid applications
INC source: INC-C13714
Design Theme: Theme Cosmos, Constellation
In Constellation/Cosmos hybrid applications, grid navigation based on the directional arrow keys has been corrected for Constellation tables displayed in the application.
Edit buttons for delegated data types have contextual label
INC source: INC-C10332
In the table that displays any data types delegated to the operator or access group, each row's Edit button has an updated label that will include the data type name which it corresponds to.
Selecting a CaseNavigation menu item moves focus to new content
INC source: INC-255036
When selecting a menu item from the CaseNavigation menu in a work object in Theme Cosmos, focus will be sent to the newly-updated content below the main work area.
Smart tips on controls in table cells dismiss when navigating away
INC source: IN-C15010
Controls placed in optimized table cells that have the Smart Tip action configured to display on focus will now properly dismiss the smart tip when the user navigates away from the cell using the arrow keys.
Captions align with visible heading for tables
INC source: INC-C15050
Tables in Constellation and hybrid applications have had their generated captions updated to match the visible heading text displayed above the table, which may include a view name if it has been personalized. This also applies to the table on the Insights landing page, which now has the caption of "Insights: All" by default rather than just "All".
Expand/Collapse dynamic layout headings provide visible focus indicator
Dynamic layout headings configured to be expandable/collapsble will not provide an OOTB focus indicator when users navigate to the heading using the Tab key
Linked email attachments added to other cases are labeled
INC source: INC-C15065
When an email attachment is linked (through OOTB activity pxLinkAttachmentToCase) to another case, the Link-Attachment record was missing the pyMemo text. As a result, under the Recent content of the case (OOTB section pyCaseRelatedContent), the name of the linked email attachment is blank. This has been corrected by adding logic to add the pyMemo text when an email attachment is linked to another case.
Notifications list items in the Notification dialog have incorrect roles removed
INC source: INC-C17010
Design Theme: UIKit
The list of notifications that appear in the dialog after activating the Notifications button in the header of UIKit applications will no longer introduce structural errors found through automated testing tools
Decorative icon in Autocomplete configured to display with caret is hidden to assistive technologies
INC source: INC-C1098
Autocompletes that are configured to display as a combobox with field and button now has the aria-hidden="true" attribute contained on the unlabeled/unfocusable button. Keyboard interaction with the autocomplete combobox remains unchanged.
Focus returns to sorted column when using shift+tab to bring focus back into optimized table
INC source: INC-C13693
When a sort has been applied on a column in an optimized table and the user presses tab to move focus out of the grid and onto the next focusable element, pressing shift+tab will allow keyboard focus to return back into the grid as expected.
Multiselect keyboard instructions localize
INC source: INC-C8551
Keyboard instructions provided for multiselect controls now localize correctly into other languages.
Focus indicator styles added for submenu left navigation items in UIKit
INC source: INC-C9110
Design Theme: UIKit
Parent submenu items in the left navigation panel of UIKit applications, such as “Create” and “Following” have had their styles updated to provide a visible indicator when focused with keyboard.
Custom filters in reports have role of link
INC source: INC-C11122
Custom filters in a report are now semantically links rather than having role=”document”.
CaseNavigation menu items provide aria-current attribute on initial load
INC source: INC-C4344
When a work object is loaded for the first time, one of the menu items in CaseNavigation is selected and showing its respective contents by default. The current menu item will now have the aria-current=”true” attribute on initial load rather than only appearing after the user makes an explicit selection from CaseNavigation.
Insight legend text displays full label in tooltip
INC source: INC-C4727
Legend values will display the full label value when users bring focus the legend value with keyboard or hover with the mouse. In the case that the legend text is truncated on the UI when too long, the full value will display in this tooltip.
Search results count announced by screen readers in delegated rules table
INC source: INC-C10427
When searching through results in the delegated rules table, the text displaying the number of results will be announced by screen reader users when the value changes.
UIKit Dashboard worklist listbox has improved interaction for keyboard and screen reader
INC source: INC-C9107
Design Theme: UIKit
The combobox and listbox used to select an operator or work queue for the worklist table on the UIKit Dashboard landing page has had its roles and attributes updated to provide better context for screen reader users as they navigate the listbox items as well as visible focus indicators when navigating with keyboard.
Decorative button icon hidden to assistive technologies in Autocomplete
INC source: INC-B31175
INC-C15021
INC-C36543
The button displayed on the far-right of an autocomplete control when the setting “Display as combobox” is selected is now hidden to assistive technologies as it cannot be navigated to with keyboard. The same functionality is available to keyboard users by pressing the down arrow key when focus is within the autocomplete.
Validation messages are announced by screen readers in Field mapping wizard dialog
INC source: INC-C9840
Success and error messages in the validation stage of the field mapping wizard will now be announced by screen readers when they appear.
Form fields controls in field mapping wizard dialog have programmatic labels
INC source: INC-C9609
The “Property to match existing records by” and “Update type” form fields on step 2 of the field mapping wizard now have associated programmatic labels.
Help icon with overlay on focus has properly localized text
INC source: INC-C1635
The “help for” text that precedes the configured helper text in the Help icon with overlay on hover helper text option will now localize into different languages.
Error icon does not overlap with checkbox
INC source: INC-B51509
Error icons for validation messages on a checkbox field will no longer overlap visually with the checkbox itself.
Helper text moved from list item to menu item in a menu
INC source: INC-B21813
The title attribute generated when helper text is configured on a menu item in a Navigation rule has been moved from the parent list item element to the respective menu item element within the menu. This allows the text to be announced by NVDA when focus is placed on the menu item.
Select File(s) button in Attach Content control does not present layout table to screen readers
INC source: INC-C6160
The layout table structure used in the Attach Content dialog has been hidden to assistive technologies on the Select File(s) button used to add attachments to a work object.
Menu items provide full label as aria-label when truncated
Resolved in: 8.8.5, 23.1.3, 24.1.4, 24.2
INC source: INC-B11124
Menu items in a menu that contain a label longer than 25 characters will be visually truncated with ellipses. In such cases, the full label of the menu item will be provided as an aria-label to prevent reading cut off from screen reader announcements.
