All incidents addressed will be implemented within the Pega platform Infinity ’24.2.5 release and will also be in subsequent releases. Where configuration is required to adopt the fix, this will be indicated within the specific item below.
Each issue addressed is provided below, along with the original spreadsheet of these issues attached at the bottom.
Focus remains trapped in calendar dialog
Resolved in: 24.2.5, 25.1.3, 26.1
INC source: INC-D9916
Design Theme: Constellation
When navigating with keyboard in the calendar dialog of a date picker field, keyboard focus will remain trapped within the dialog until it is dismissed.
Empty div in navigational tree is hidden to screen readers
Resolved in: 24.2.5, 26.1
INC source: INC-D20715
Design Theme: UIKit, Theme Cosmos
In the Navigational tree control, an empty div in each record is no longer perceivable by screen readers when users navigate in browse mode.
Escape key dismisses menus containing only disabled menu items
INC source: INC-D12317
For menus containing only disabled menu items, Escape keypress now allows users to dismiss the menu.
Field label displayed in error message with DSS set to true when embedded in a section in a table
INC source: INC-C55697
When the DSS "displayFieldNameInValidationMsg" is set to true, invalid form fields embedded in table cells via embedded section will properly display the field's label as part of the inline validation error message.
Calendar dialog differentiates today's date and user-selected date for screen reader
INC source: INC-C56147
When a user makes a selection in the calendar dialog of a date picker control, aria-current and aria-selected attributes now accurately reflect today's date and the user-selected date, respectively.
Accordion layout group provides expanded state on change to SR
INC source: INC-C59251 INC-C53488
When expanding an accordion button within a layout group, screen readers will announce the change in state after activation.
Date range calendar dialog has semantic role and label
INC source: INC-D10078
The calendar to select a date range is now semantically a dialog with a programmatic label to reflect its purpose.
Layout table programmatically hidden in calendar dialog for date picker
INC source: INC-D10282
The calendar dialog launched through a date picker control no longer contains a layout table around the month and year spinboxes.
Case view does not introduce horizontal scroll bar at reflow dimensions
INC source: INC-D1723
Design Theme: Theme Cosmos
When viewing a work object screen at reflow dimensions (320x256px or 1280x1024px + 400% zoom), updates to responsivity CSS prevents horizontal scrolling.
