Applies to Pega Platform™ version 8.5 through Pega Platform version 8.8.
Known Issue
Apache Kafka version Proprietary information hidden fails to clean up log compacted topics in Pega deployments on Microsoft Windows Server 2016 running on IBM WebSphere Application Server 5.5 bundled with IBM Java 8 and Fix Pack 19 (also known as Version Proprietary information hidden).
Exception in the Kafka server.log
[2021-11-09 13:06:11,084] ERROR Failed to clean up log for df_run_metrics-4 in dir
D:\opt\PEGA\ldn\test\temp\kafka-data due to IOException (kafka.server.LogDirFailureChannel)
java.nio.channels.ClosedChannelException: null
at sun.nio.ch.FileChannelImpl.ensureOpen(FileChannelImpl.java:122) ~[?:1.8.0]
at sun.nio.ch.FileChannelImpl.read(FileChannelImpl.java:737) ~[?:1.8.0]
at org.apache.kafka.common.utils.Utils.readFully(Utils.java:831) ~[kafka-clients- Proprietary information hidden.jar:?]
at org.apache.kafka.common.record.FileRecords.readInto(FileRecords.java:116) ~[kafka-clients- Proprietary information hidden.jar:?]
at kafka.log.Cleaner.cleanInto(LogCleaner.scala:601) ~[kafka_2.11- Proprietary information hidden.jar:?]
at kafka.log.Cleaner.cleanSegments(LogCleaner.scala:518) ~[kafka_2.11- Proprietary information hidden.jar:?]
Solution
Prior to Pega Platform version 8.6, the Pega-provided Kafka distribution uses two log compacted topics: __consumer_offsets, and df_run_metrics.
To resolve the Kafka server.log exception, convert these three topics to uncompacted topics by specifying the Kafka cleanup policy as delete:
$.\kafka- Proprietary information hidden\bin\windows\kafka-topics.bat --zookeeper localhost:2181 --topic __consumer_offsets --alter --config cleanup.policy=delete
$.\kafka- Proprietary information hidden\bin\windows\kafka-topics.bat --zookeeper localhost:2181 --topic df_run_metrics --alter --config cleanup.policy=delete
$.\kafka- Proprietary information hidden\bin\windows\kafka-topics.bat --zookeeper localhost:2181 --topic stream_dataset_offsets --alter --config cleanup.policy=delete
Related content
Third-party documentation
IBM WebSphere Application Server v8.5.5 Fix Pack 19
Kafka Topic-Level Configs See cleanup.policy.
