Issue
If your Constellation application is on Pega Platform™ release 26.1.1 and your hotfix inventory includes HFIX-D3341, users may see a blank screen when launching a Constellation portal, and cases, views, and editing views may also fail to load.
Symptoms and impact
- A blank screen appears when a user launches a Constellation portal.
- Portals, cases, views, or editing views do not load while authoring the application.
Solution
To resolve this issue in Pega Platform™ release 26.1.1, apply HFIX-D4563.
If you are using a Constellation application for Pega Strategic Apps, raise an incident with Global Client Support through My Support Portal to obtain the fix.
