Cognizant
CH
Wrong audit history message when using pxLinkAttachmentToCase
I am using pxLinkAttachmentToCase Activity to link a Data-Workattach-File to a case.
I noticed that in the Audit History the messages contain a placeholder instead of the actual filename, like "A file has been attached: {1}." (instead "{1}" the file's name should be shown). See: AuditTrail.png
Digging into the code: there is a Property-Set step in pxLinkAttachmentToCase Activity which assembles the audit history message (pxLinkAttachmentToCase.png):
Param.AuditNote = @(Pega-RULES:String).equals("", Param.AuditNote)? "FileAttached" : Param.AuditNote + "\t" + LinkAttachPage.pyNote
The Param.AuditNote can either be
"FileAttached"
or
as the ternary expression does not have brackets around it.
Checking an other Activity AttachFile shows that we need the file name parameter after "FileAttached" as well (AttachFile.png), so I suggest to fix the above line in pxLinkAttachmentToCase by adding brackets:
(@(Pega-RULES:String).equals("", Param.AuditNote) ? "FileAttached" : Param.AuditNote) + "\t" + LinkAttachPage.pyNote
Pega versions I checked: 7.2, 7.2.2
If it has already been fixed, please provide the hotfix I need to apply.
Attila
"FileAttached"
or
Attila
***Updated by moderator: Lochan to add BUG ID***
