Perficient
Last activity: 29 Aug 2017 17:12 EDT
How to customize the messages appearing in the Description column of the history section in the audit tab
Hello all,
I am trying to setup the Audit Sub tab in pyCaseContent in order to get the logs on changes made on the work object. I am using the pyCaseAudit for the same which uses pyCaseHistory. My question is regarding the History (pyCaseHisrtory and pyCaseHistoryContent) grid. So whenever a change is made to an object the description of this change appears in the Description column of this grid referenced using the pyMessageKey property. Can someone please tell me how to setup/modify these messages appearing under the Description column of the History grid? Thanks!
