work object creation types
what are the all various way for creating work object in pega?
In versions of Pega 7, think of work objects as "cases". Cases are instances of your case types, which by default inherit from Work-Cover-.
You can create cases in a variety of ways:
1.From the +Create menu in Designer Studio and other end user portals
2.By adding the Create Case shape to a flow
3.By calling an activity
For more information on the Create Case shape, see: https://pdn.pega.com/node/1018756
Thank You.
Hello yatishr5
The content of this post is similar to another post of yours: Work object creation rules
To avoid confusion to the commnuty members, we will be closing this post as duplicate. Kindly continue the discussion over the newer post.
