Accenture
Last activity: 2 Oct 2017 23:17 EDT
How to restrict the Work Object creation on particular access group?
I have a question here, how to restrict the Work Object creation on particular access group?
For Example : Currently if i login with Administrator access group i am able to create 5 different Work objects(on click of create button i am getting 5 options called A, B, C, D and E).
My requirement is if i login with "Manager" access group i want only 2 Work Object Creation privilege (I.e A and C).
How to restrict this Work Object creation based on access group ?
I have tried with "Access Group" Work Pool and Case Type Settings option but no luck.
I am using 7.1.9 .Please help me to resolve this issue.
Sowmya
***Updated by moderator: Lochan to branch reply to create this new post***
Hi Sowmya,
You can try to add privilege on pyStartcase flow of the particular case type.
The privileges are present in Process tab of flow.
Hope this helps.
--Ravi.
