While running Bot from Bot manager windows session not logged off.
While running Bot from Bot manager windows session not logged off, please guide me to resolve the issue.
I would suggest opening a support request for this issue. There may be a problem with your solution that would need to be examined by someone who could access your machine. If you do open an SR, please record the number here so that if the resolution is not specific to your solution, it can be added to the post.
