Skandiabanken
SE
Wait shape is not working for time interval
Hi ,
The process has to be suspended for 2 mins .After the configured interval is passed,the process should progress forward automatically . but currently it's not moving forward to create an assignment automatically.
Time Interval : 2 Mins. and "pyContinueAfterWait" flow action is defined on outgoing connector of wait shape.
PRPC;71.8
Please suggest.
Skandiabanken
SE
>> Yes ..Case is configured with Default Locking.
>> Case is not locked.
we don't see errors in broken process.
Skandiabanken
SE
Skandiabanken
SE
I did same configuration in 7.2 version but it's not working .
Anybody had this issue ?
Coforge DPA Limited
Hi Brahmesh,
Is this issue fixed. We are also facing the same issue. Could you please let us know the solution if any found.
Shalini Kopuri
- we noticed the same issue
- I assume that the task will be queued by the time we specify on wait shape
- and the processing would depend on first in first out of queue list which could be consuming time...
- anyone please weigh-in on my understanding as we often notice SLA firing late.
also as Pankaj Rawal said - please double check if the agent 'ServiceLevelEvents' is enabled on the system.
cognizant
Hello ,
If anyone has resolved this issue ,please let me know .
Capgemini
Hi , Any update on this issue .I am also facing the same issue and waiting for solution.
Dasaradha
Updated: 30 Jul 2017 23:21 EDT
Hi Dasaradha,
Since this post is not recent, we are are not sure if this will be updated by the original poster. Here are 2 Support Articles I found over PDN which looks to be related:
Wait shape is not waiting for the time-interval configured
Wait shape not waiting for all cases to be resolved
In case, these do not help you, please create a new post by clicking Write a Post button present on the top right of this page.
Wipro
Hi Brahmesh,
if it is taking exactly 15 miniutes to continue the process, then it is default behaviour of Queue(SYSTEM-QUEUE-SERVICELEVEL).Please check the attachment this can be helpfull.
Hussain
Sopra Steria
FR
I read your attachment and we have exactly the same problem but I don't understand :
"Reason: If the System queue contains more cases in queue, then by default pega will give 15 min for wait. If queue is not having much case, then after 1 minute system will continue from wait shape."
Just: why ? You mean if there is more than one item in the queue, Pega will dequeue all of them 15 minutes later ? Why ?
Orianne
Updated: 17 Aug 2018 5:26 EDT
Tata Consultancy Services
HI Brahmesh,
We faced similar issue so can you try using SLA.
if you want sla configuration i will provide you.
Have you tried whatever i suggested above?
Sopra Steria
FR
What do you mean by using SLA ?
can you try to add SLA in sla after reaching goal you can run activity in which you can do resume flow.
Sopra Steria
FR
Hum, I'm interested in the SLA configuration you are talking about.
so can you try using SLA and revert back to me if u need any help.
HI have you tried ?
CollabPartnerz
HI,
Below post is similar to your post.
Is the Case configured with Default locking ?
Also can you check if the Case is locked during that time ?
Wait shape is processed by SLA Agent, you can also check queue instances to see if it has been processed and if there were any errors.
