CGI
Urgent: How to log IP address of user trying to login the system from SSO
We have user story to log the IP address of user trying to login the system using SSO.
It should capture for success and failure login attempt.
How can we get IP address of user trying to login the system in SSO activity.
Thanks in Advance!
Best Regards
U Rajasekhar
Updated: 25 Jul 2016 9:32 EDT
Hello
For successful log in we can definitely find out the client IP address from clipboard page.
pxRequestor.pxReqRemoteAddr or pxRequestor.pxReqRemoteHost can give you the client IP add.
However, i am not sure how to track the IP address for failed log in ?
Rajeev Ranjan any thoughts ?
PEG
PL
For failed case also, we can get that but we have to extract from the authentication activity. We could log that value then and there.
CGI
Hi Rajeev
Can you share
- the code to get IP address in SSO authentication activity.
- After which step in SSO authentication activity we have to write the code.
Thanks & Regards
U Rajasekhar
Verizon Wireless
We are using pega cloud and these properties are blank . any idea how to populate ?
CGI
I am not getting IP address in SSO authentication activity.
Can someone guide us
Thanks & Regards
U Rajasekhar
CGI
Thanks & Regards
U Rajasekhar
In your SSO authentication activity you can access a HTTPServletRequest facade object and access HTTP Request headers and general request object methods. This can be used to get the client IP address. However, it depends on other infrastructure in place between the client browser and PRPC.
It's very unlikely that you will have clients connecting right to the PRPC JVM. You will probably have many JVM nodes and web servers and load balancers in front of PRPC. For example:
Browser->Cisco F5->Web Server(More than 1)->PRPC Node(More than 1)
What you don't want to get is the IP address of the middleware components between the client browser and PRPC.
For example:
request.getRemoteAddr()
This will return the IP address of the incoming connection that could be the web server or load balancer IP address. In the example above the getRemoteAddr method would return the IP address of the web server.
As the middleware components route the traffic to the JVM they can and usually will add a HTTP header containing the client ip address.
Update your login activity and the following code to a new Java step right at the top of the activity:
For example:
javax.servlet.http.HttpServletRequest request = (javax.servlet.http.HttpServletRequest)tools.getRequestor().getRequestorPage().getObject("pxHTTPServletRequest");
/* Debug only, comment out when done testing */
oLog.infoForced("Incoming headers for login:");
java.util.Enumeration e = request.getHeaderNames();
String header = null;
while (e.hasMoreElements()) {
header = (String) e.nextElement();
oLog.infoForced(header + ": " + request.getHeader(header));
This will output to the logfile all the HTTP headers of the incoming request.
Make sure the login activity is checked in and test the login.
Get the logfiles and look to see if you have the client IP address contained in one of the headers?
Yes:
Easy, you just need to get the header value. Not sure what you need to do with it so just putting it in a local variable defined in the activity.
Define a local string variable on the Parameters tab of the activity: clientIP
Comment out the logging for the output of all header.
Set clientIP from the http header:
clientIP = request.getHeader(“<headerName>”);
Now you can you use this variable for other processing in the activity. (Local.clientIP)
No:
If you don’t see a header with the client value then it's time to send an email to the owners of the middleware components and ask them to add the client IP address to a HTTP header. It’s important that you contact the right team. In the example above you would need to contact the Cisco F5 admin to get the client IP added. Why? Because it’s the first middleware component the browser talks to.
Hope this helps.
CGI
Thanks Chris,
We will work on it and update you.
Best Regards
U Rajasekhar
CGI
Thanks Chris....
For example:
For example:
Yes:
No:
Hope this helps.
