CGI
Urgent: How to set the focus to selected row in Tree Grid
Operator A selected a row from Tree Grid and submitted for approval to Operator B. When Operator B opens the case FOCUS SHOULD BE SET TO SELECTED ROW FROM TREE GRID BY OPERATOR A.
Please share the steps details.
Thanks in Advance
Shell
Hi Rajasekhar,
Thanks for posting your queries to PSC !!
Please check the below links. They might help you.
https://collaborate.pega.com/question/how-retain-selected-row-repeating-grid-layout-page-load
- Chinmai Sravanthi.
CGI
Nothing to our requirement.
We need "Operator A selected a row from Tree Grid and submitted for approval to Operator B. When Operator B opens the case FOCUS SHOULD BE SET TO SELECTED ROW FROM TREE GRID BY OPERATOR A."
CGI
CGI
Can someone reply to below query
CGI
Hi RajaSekhar,
I think a similar query was posted here :
https://collaborate.pega.com/question/treegrid-not-expanding-prpc-v718
If you want to say a particular row in the tree gird to be expanded, you would need to set its *AND* all its parents pyExpanded property to true.
You can do this in a pre flow action activity
CGI
Thanks....
We am not looking for tree expand.
We have a query related to Focus particular row in tree grid.
How to set the focus to selected row in Tree Grid and retain when case moves from one user to another user in workflow.
I am not sure I understand, when you place a focus on a particular row on the tree gird, isnt it not automatically expanded to show it ? (May be you can write additional logic to set the bgcolor)
If Operator A selects a particular node, set some property "isSelected" to true
Check for this property and set the pyExpanded to true before operator B views it
CGI
Thanks....
We are not looking for tree expand i.e. pyExpanded. We are setting pyExpanded to true before operator B views.
We have a query related to Focus particular row/ node in tree grid.
How to set the focus i.e. Highlighted to selected row/node in Tree Grid and retain when case moves from one user to another user in workflow.
Do you mean to say that your tree grid is editable and you want the particular row to be expanded and "focused" so that you can edit it automatically ?
If the tree gird is not editable, gaining focus would only probably set the background color right ?
You want to set the focus ona row from an activity / DT is that right ?
CGI
Thanks Krithiga,
We have both scenarios
Scenario 1: CSR has selected a row in tree grid and case is routed to manager for approval i.e. tree gird is not editable, gaining focus would only probably set the background color right. How to set focus.
Scenario 2: PSR open the case for update the selected a row in tree grid by CSR i.e. tree grid is editable and you want the particular row to be expanded and "focused" so that you can edit it automatically. We are able to expand. How to set focus.
Thanks in Advance........
CGI
Hi Krithi,
Thanks Krithiga,
CGI
CGI
CGI
CGI
CGI
CGI
CGI
CGI
