CGI
Last activity: 17 Jun 2016 8:13 EDT
Urgent: Issue with Layout group
In Layout group, When I am in 3rd tab and on click of button, we refresh a parent section of Layout group. Issue is focus move to first tab.
Expected is focus should stay at 3rd tab only.
Thanks in Advance!
Best Regards
U Rajasekhar
CGI
Hi Vikas and Sathish,
We are able to keep the focus on current tab in Layout group by refreshing current tab section.
Thanks for your time and guidance.
Best Regards
U Rajasekhar
Hi Rajasekhar
Could you elaborate on the use case ?
When the parent section is refreshed, the focus moves to the default at design time. In your case, if it is the first tab, that'll be retained.
If you just want the contents in your tab/ any other tab refreshed, you might want to use "refresh other section" instead.
CGI
Hi Krithi,
UI Layout is as below
Use Case: On click of clear button, search data on all tabs and results should be cleared. Focus should stay in current tab only.
Approach 1: On click of clear button, we refresh the parent section. Data is cleared from all UI tabs but issue is focus moves to first tab
How can we set default tab at design time in Layout group?
How can we set default tab at runtime in Layout group?
Approach 2: On click of clear button, we refresh the Current search section. Data is cleared from current UI tab and focus stays at current tab. Issue is search section data on UI from other tab is not cleared. When we click other tabs, can see search data on other tab but on clipboard data is blank/empty i.e. our understanding is other tabs are not refreshed.
How can we refresh the section on click on tab in Layout group?
Hi Krithi,
Thanks in Advance!
Best Regards
U Rajasekhar
If you use a Tab group, you can enable refresh when active. That approach should meet your needs as described here.
CGI
Hi Rett,
We are using Layout group and also Pegasystems has suggested to client to use Layout group, instead of Tab group.
Thanks & Regards
U Rajasekhar
Cognizant
Hi Rajashekar
How can we set default tab at design time in Layout group?-- For this , open the section in which you referred layout group. Select(Click) the tab which you wanted by default (on the section after checking out the rule). Check in the section rule.
After refresh also screen will go to the tab you wanted.
Sam
CGI
Layout Group tabs doesn't retain focus on section refresh.It just takes us back to the way it was configured during design time i.e. to the initial state.
Please use tab group instead to retain the focus post refresh.
CGI
Hi Sathish,
As mentioned in Re: When should we use Layout Tab and Layout Group.
Can we Implement Use Case with Layout group?
We have tried following approaches and queries below.
How can we set default tab at run time in Layout group?
Hi Sathish,
CGI
Approach 2: On click of clear button, we refresh the Current search section. Data is cleared from current UI tab andfocus stays at current tab. Issue is search section data on UI from other tab is not cleared. When we click other tabs, can see search data on other tab but on clipboard data is blank/empty i.e. our understanding is other tabs are not refreshed.
Can someone reply to above queries.
Thanks & Regards
U Rajasekhar
You cannot configure a layout group to have this behavior, neither default tab nor refresh on click. As Sathish already suggested, please use tabbed layout.
CGI
Best Regards
U Rajasekhar
