Upgrade from PRPC 7.2 to 7.41 error: Database-BadClassDef PegaCard-Sd-DisputeAcq-Visa
I just upgraded PRPC from 7.2 to 7.41 following the upgrade guide. Post upgrade, I restarted the application and when reviewing the logs, noticed a lot of warning messages that were all similar.
2019-04-11 13:46:27,404 [ acs27w001] [ STANDARD] [ ] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-ACTIVITY PEGAPDFS-WORK UPDATEPROPERTY #20170221T085733.375 GMT due to Database-BadClassDef PegaPDFS-Work; This may cause the wrong rule to run during rule execution.
2019-04-11 13:46:27,858 [ acs27w001] [ STANDARD] [ ] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL PEGACARD-SD-DISPUTEACQ-VISA GETDISPUTEDETAILSRESPONSE_PE #20180123T135831.226 GMT due to Database-BadClassDef PegaCard-Sd-DisputeAcq-Visa; This may cause the wrong rule to run during rule execution.
2019-04-11 13:46:27,936 [ acs27w001] [ STANDARD] [ ] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL PEGACARD-SD-DISPUTEACQ-VISA GETDISPUTEDETAILSRESPONSE_CD_M #20180320T115926.631 GMT due to Database-BadClassDef PegaCard-Sd-DisputeAcq-Visa; This may cause the wrong rule to run during rule execution.
2019-04-11 13:46:27,936 [ acs27w001] [ STANDARD] [ ] [ ] (res.CacheDataToCandidateMapper) WARN - Unable to load RULE-OBJ-MODEL PEGACARD-SD-DISPUTEACQ-VISA SIMULATEVCR_GETDISPUTEDETAILSRESPONSE_CD_CR #20180123T135831.455 GMT due to Database-BadClassDef PegaCard-Sd-DisputeAcq-Visa; This may cause the wrong rule to run during rule execution.
Everyone of the warnings, reference the Bad Class Def of PegaCard-Sd-DisputeAcq-Visa. I am not seeing this class in the upgrade version nor in the non-upgrade production environment. We are an issuer only and I'm thinking this could be an Acquirer class def. Is this an error? How do I clean this up so it isn't always showing in the logs for each restart?
