How to upgrade from CPM 7.13 to CS 7.2.2 in PRPC 7.2
We are performing CPM framework upgrade to latest version on pega 7.2.2.
When we are looking to update the application stack to the latest versions of CPM, some of the below application rules doesn’t have new versions. Instead , new application rules are created in a different name .
For example, PegaCPMFS is not having a new higher version application rule, but an application rule with a different name - CustomerServiceForFS is created by pega.
Should we change the build-on application names or update the existing application rules in our stack to refer to the new ruleset versions?
The following is our current application stack.
| application | version |
| Implementation layer | 01.01.01 |
| Framework Layer | 01.02.01 |
| PegaCPMFS | 7.13 |
| CPMForFS_CPM | 7.13 |
| CPMForFS_PegaChannelServices | 7.13 |
| PegaFSIFLegacyAssets_Base | 7.14 |
| PegaFSIF_Base | 7.14 |
| PegaRequirements_Base | 7.14 |
| SCM | 7.11 |
| PegaRULES |
7.1 |
