HCL
Upgrade Estimator Error
When we are trying to run UpgradeEstimator Tool on PRPC 6.2 SP2 towards 7. However, we are facing issue which we couldn't be able to proceed further on Results. Error
as follows "Unhandled exception executing JSP: Unhandled exception executing JSP: Unhandled exception executing JSP: Unhandled exception executing JSP: Error loading Declare_PortalInfo
with definition RULE-DECLARE-PAGES DECLARE_PORTALINFO #20160812T065343.486 GMT using activity {pyClassName=Code-Pega-List, pxObjClass=Rule-Obj-Activity,
pyActivityName=tyGeneratePortalInfo}" Any Suggestions to Proceed Further? Thanks in Advance.
Please “Save-As” the 'txWorkAreaMiddlePanel’ section rule into your application RuleSet and Open the cell properties of ”WorkArea” Control and click on “Ok” button. It will resolve the issue.It will look like below screenshot.
HCL
Thanks for your suggestion Subramanyam. It worked out.
LLoyds Banking Group
Hi All-
We tried doing the samething what was mentioned above and when I tried to do that , I was getting the below rules missing error , could you please help.
Hi All-
General Error: The page contains an undefined property: .pySpecialityControl
The page contains an undefined property: .pyThirdPartyParams
Validation failed: Errors Detected.
General Error: The page contains an undefined property: .pySections(1).pyRefreshWhenActive
The page contains an undefined property: .pySections(1).pyTabAlignment
The page contains an undefined property: .pySections(1).pyStretchTab
General Error: The page contains an undefined property: .pySections(1).pySectionBody(1).pyColumnResizing
General Error: Validation failed: Errors Detected.
General Error: The page contains an undefined property: .pySections(1).pySectionBody(1).pyTable.pyRows(1).pyCells(1).pyEditOptions
The page contains an undefined property: .pySections(1).pySectionBody(1).pyTable.pyRows(1).pyCells(1).pyColumnFilteringDropDown
General Error: The page contains an undefined property: .pySections(1).pySectionBody(1).pyTable.pyRows(1).pyCells(2).pyEditOptions
The page contains an undefined property: .pySections(1).pySectionBody(1).pyTable.pyRows(1).pyCells(2).pyColumnFilteringDropDown
Please create the new section rule with the name 'txWorkAreaMiddlePanel’ into your application RuleSet and drag the ”WorkArea” Control and open the properties as shown in previous post screenshot and click on “Ok” button. It will resolve the issue.
Thanks for the response.
Now I am getting a different error on the screen.
Caught exception: com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find instance @baseclass.tyProgressbar of type Rule-Obj-HTML. |
com.pega.pegarules.generation.internal.assembly.FUAInstance.getRules(FUAInstance.java:2408) |
com.pega.pegarules.generation.internal.assembly.FUAInstance.getClassSource(FUAInstance.java:2575) |
com.pega.pegarules.generation.external.assembly.Assembler.getClassSource(Assembler.java:940) |
com.pega.pegarules.generation.internal.cache.RACacheImpl.assembleRule(RACacheImpl.java:2729) |
com.pega.pegarules.generation.internal.cache.RACacheImpl.buildAndOrLoadJavaClass(RACacheImpl.java:3008) |
com.pega.pegarules.generation.internal.cache.RACacheImpl.getGeneratedJava(RACacheImpl.java:9312) |
com.pega.pegarules.generation.internal.cache.RACacheImpl.addEntryToMemoryCache(RACacheImpl.java:8906) |
com.pega.pegarules.generation.internal.cache.RACacheImpl.find(RACacheImpl.java:1878) |
com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.getInternal(FUAManagerImpl.java:1441) |
com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.get(FUAManagerImpl.java:1398) |
com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:242) |
com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3482) |
com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3259) |
com.pegarules.generated.activity.ra_action_showstream_3916fe8b8ef20c638e8a15b2521163df.step4_circum0(ra_action_showstream_3916fe8b8ef20c638e8a15b2521163df.java:435) |
com.pegarules.generated.activity.ra_action_showstream_3916fe8b8ef20c638e8a15b2521163df.perform(ra_action_showstream_3916fe8b8ef20c638e8a15b2521163df.java:136) |
com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2890) |
com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:617) |
com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:580) |
com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:2020) |
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390) |
sun.reflect.GeneratedMethodAccessor70.invoke(Unknown Source) |
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37) |
java.lang.reflect.Method.invoke(Method.java:611) |
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1054) |
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:776) |
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:324) |
com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:680) |
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:312) |
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263) |
com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:236) |
sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source) |
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:349) |
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:390) |
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingException(PRBootstrap.java:412) |
com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168) |
com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source) |
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:277) |
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:222) |
com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:370) |
com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:249) |
sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source) |
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:439) |
com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:99) |
com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:89) |
javax.servlet.http.HttpServlet.service(HttpServlet.java:718) |
javax.servlet.http.HttpServlet.service(HttpServlet.java:831) |
com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1694) |
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:970) |
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:508) |
com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:181) |
com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3994) |
com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:276) |
com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:945) |
com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1592) |
com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:191) |
com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:454) |
com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:516) |
com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:307) |
com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:84) |
com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) |
com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) |
com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) |
com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) |
com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) |
com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) |
com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) |
com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1662) |
Which caused: com.pega.pegarules.pub.PRRuntimeException: Failed to find instance @baseclass.tyProgressbar of type Rule-Obj-HTML. |
com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3526) |
Which caused: com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError |
com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:683) |
In the logs, I could see the below error:
java.lang.NullPointerException
at com.pegarules.generated.html.ra_stream_typrogressbar_969847f849177b42ad44c68997f9233f.execute(ra_stream_typrogressbar_969847f849177b42ad44c68997f9233f.java:107)
... 62 more
2017-07-06 15:16:47,130 [sDevTst01,maxpri=10]] [ STANDARD] [GroupECMCCE:01.03.01] (uteRuleComplexity.Rule_.Action) INFO 8761670 - Effort Estimator has started for Rule Type : Rule-PortalSkin
2017-07-06 15:16:48,209 [sDevTst01,maxpri=10]] [ STANDARD] [GroupECMCCE:01.03.01] (uteRuleComplexity.Rule_.Action) INFO 8761670 - Effort Estimator has ended for Rule Type : Rule-PortalSkin
2017-07-06 15:16:48,210 [sDevTst01,maxpri=10]] [ STANDARD] [GroupECMCCE:01.03.01] (uteRuleComplexity.Rule_.Action) INFO 8761670 - Effort Estimator has started for Rule Type : Rule-HTML-Section
2017-07-06 15:16:48,726 [sDevTst01,maxpri=10]] [ STANDARD] [GroupECMCCE:01.03.01] (erRules.Rule_PortalSkin.Action) ERROR 8761670 - Exception caught while evaluating when
java.lang.IndexOutOfBoundsException: Index: 330, Size: 329
at java.util.ArrayList.get(ArrayList.java:360)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.getPageValue(ClipboardPropertyBase.java:1126)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.resolveEmbeddedPages(PropertyReferenceImpl.java:1771)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGetString(PropertyReferenceImpl.java:1362)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getString(PropertyReferenceImpl.java:1166)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString(ClipboardPageImpl.java:1070)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString(ClipboardPageImpl.java:1018)
at com.pegarules.generated.activity.ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.step4_1_circum0(ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.java:1078)
at com.pegarules.generated.activity.ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.step4_0_circum0(ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.java:997)
at com.pegarules.generated.activity.ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.perform(ra_action_tyfilterrules_725e3c723cdac4bfc6b14a7fc861f26a.java:156)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2890)
at com.pegarules.generated.activity.ra_action_txbrowserulesandversion_55fe41349cd44223a44a925ff8368795.step6_circum0(ra_action_txbrowserulesandversion_55fe41349cd44223a44a925ff8368795.java:1590)
at com.pegarules.generated.activity.ra_action_txbrowserulesandversion_55fe41349cd44223a44a925ff8368795.perform(ra_action_txbrowserulesandversion_55fe41349cd44223a44a925ff8368795.java:182)
at com.pegarules.generated.activity.ra_action_tycomputerulecomplexity_a84cc5d619812c82294332a8316575f0.step2_circum0(ra_action_tycomputerulecomplexity_a84cc5d619812c82294332a8316575f0.java:554)
at com.pegarules.generated.activity.ra_action_tycomputerulecomplexity_a84cc5d619812c82294332a8316575f0.perform(ra_action_tycomputerulecomplexity_a84cc5d619812c82294332a8316575f0.java:89)
at com.pegarules.generated.activity.ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.step4_3_circum0(ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.java:828)
at com.pegarules.generated.activity.ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.step4_0_circum0(ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.java:624)
at com.pegarules.generated.activity.ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.perform(ra_action_txcomputerulecomplexity_72d73ecdf44184ae85f0ed0502d2bdf7.java:140)
at com.pegarules.generated.activity.ra_action_txestimateallruleeffort_606fbbccfd5ab9f1e63d00f118e061d5.step19_circum0(ra_action_txestimateallruleeffort_606fbbccfd5ab9f1e63d00f118e061d5.java:2510)
at com.pegarules.generated.activity.ra_action_txestimateallruleeffort_606fbbccfd5ab9f1e63d00f118e061d5.perform(ra_action_txestimateallruleeffort_606fbbccfd5ab9f1e63d00f118e061d5.java:483)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:617)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:545)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:572)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:253)
MacQuarie Group Ltd
Hi Chaitu,
If you have already resolved this issue, could you please explain here?
Lakshman.
