Unwanted flow action getting executed due to FlowActionHTML_Simple.
I'm having a situation that unwanted flow action getting executed due to FlowActionHTML_Simple section. Below is the sample screen of flow,
For the assingment, harness set as perform and inside the perform harness pyActionArea and FlowActionHTML_Simple included.
Assume currently flow is waited on this assignment. At this point, because of the FlowActionHTML_Simple, FlowAction1 is already executed.
(Assume newAssignPage.pyAssignActions(1) is FlowAction1)
I changed the assingment harness to Review and removed FlowActionHTML_Simple section from the perform harness and checked, both time it worked - meaning, it didn't call FlowAction1.
Would you please suggest a solution. And also if anyone can share a detail description about FlowActionHTML_Simple section's functionality, I will be very greatful.
***Updated by Moderator: Marissa. Removed user added #helpme and Ask the Expert group tags. Apologies for confusion, shouldn't have been an end-user option; updated categories***
