Last activity: 8 Sep 2016 16:49 EDT
Unauthenticated or not available error with Pega LDAP Url
We have 5 different Pega LDAP urls. LDAP1 and LDAP2 are not working. LDAP3 and LDAP4 and LDAP5 urls are working fine. We are gettting the below error in logs while accessing LDAP1 and LDAP2 urls.
Login screen error:
Status fail
Message There has been an issue; please consult your system administrator
Operator ID Unauthenticated or not available
Requestor ID HA2A751F818D9FED213F4F7EF4B957C5A
Timestamp Wed Sep 07 11:58:43 EDT 2016
Engine Version PegaRULES 7.10 ML8 (coreAssemblyCached_718_675)
Pega Log errors:
"Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'XXXLDAPAUTHENTICATION' that applies to 'Code-Security'. There were 4 rules with this name in the rulebase, but none matched this request. The 4 rules named 'XXXLDAPAUTHENTICATION' defined in the rulebase are:
4 related to applies-to class 'Code-Security', but were defined in rulesets which are not in your rulesetlist: {ABCFW:02-03-02, ABCFW:02-03-01, ABCFW:02-02-01, ABCFW:02-01-01}.
Login screen error:
Status fail
Pega Log errors:
Current RulesetList:
Pega-ProcessCommander:07-10,
Pega-LP-ProcessAndRules:07-10,
Pega-LP-Integration:07-10,
Pega-LP-Reports:07-10,
Pega-LP-SystemSettings:07-10,
Pega-LP-UserInterface:07-10,
Pega-LP-OrgAndSecurity:07-10,
Pega-LP-DataModel:07-10,
Pega-LP-Application:07-10,
Pega-LP:07-10,
Pega-UpdateManager:07-10,
Pega-SecurityVA:07-10,
Pega-Feedback:07-10,
Pega-AutoTest:07-10,
Pega-A...........
***Updated by Moderator: Vidyaranjan| Included Categories***
What is the top-level exception with this "caused by"? Provide the full stack trace if possible.
Also, your "current ruleset list" is cutoff before we see what Major version of "ABCFW" you are under. I suspect you may be in 03 and will need to skim.
