Atos Consulting
Unable to start process crm.exe in Pega Robotic Automation Architect Essentials course (using Windows10)
Hi there,
I am enrolled in Pega Robotic Automation Architect Essentials, working on "Working with Windows Adapters". I’m running on Windows 10 with Robotics studio version 8.0.1016.0.
I’ve got a problem with the interrogating with a windows application. When I try to start interrogation (in this case the Path has been set to CRM) I’m getting the following error: "unable to start process crm.exe". See the attached screenshot.
What I already tried:
- Reinstall Pega Robotics Studio
- Check whether CRM.exe was located in the directory specified
- Disabling virus-scanners
- Trying other windows applications
What can there be wrong?
RJ
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
There must be something wrong with your machine if you have completed all of the steps you mentioned and it is still not working. I suggest you open an SR with our support team, so that they may take a look at your machine. Please update this post with the SR number for tracking purposes.
ING
Hi
Going through the same problem ,please let me know what is the solution for this. I also cannot create a SR
Any help would be appreciated
Facing same problem do let us know the solution.
Appreciate your help
For any issues with self-study, please email [email protected]
Bank Of America
unable to interrogate the CRM.exe. Using Windows 10
Sopra Steria AG
CH
Hi everybody
I manage to fix it: check the security rights of the CRM.EXE file and allow everyone or at least yourself with FULL CONTROL.
I am enrolled in Pega Robotic Automation Architect Essentials, working on "Working with Windows Adapters". I’m running on Windows 7 Professional with Robotics Studio version 8.0.1039.0. I’ve got a problem with the interrogating with a windows application. When I try to start interrogation (in this case the Path has been set to CRM) I’m getting the following error: "CRM.exe has stopped working". When I start CRM.exe manually it works without any errors.
I first made some test with an empty text file and an empty excel file. Both could be open by the adapter, but still the EXE was giving errors. I enhance on the security properties the user myself to have full control and now it works.
Regard Carlos
Virtusa
LK
I'm facing the same issue.Did anyone able to fix this error? I even checked the security rights of the CRM.EXE file and allowed everyone with full control.
Amex
Hi, I'm facing the same issue. Could you please let me know if you find the resolution.
Please see this post for the solution to this problem.
Datacom
NZ
Please also try disabling the Anti Virus. Had issues starting both Windows and Web interrogation and they started working as soon as I disabled the Anti-virus. I am using Windows build 1709
