Hoverstate
Last activity: 23 Aug 2018 19:03 EDT
Unable to interrogate CRM.exe application
I'm getting the following error when trying to interrogate the CRM.exe training application: Unable to start process CRM.exe. Start process injected C:\Program Files (x86)\OpenSpan\CRM Setup\CRM.exe failed. Screen shot attached. Any ideas?
TCS
i formatted the system and downgraded from windows 10 to windows 7 and its started working fine now.
Comptech Associates Inc
Did you check to see if the CRM.exe is there at the path specified? If so, I have no idea. If not, you probably forgot to indicate that you wanted CRM installed when you loaded Pega Robotics. You may be able to fix that oversight with a "repair" otherwise you'll have to uninstall and reinstall.
Hoverstate
Thanks for your reply, Ed. I did indicate that it be installed when Robotics Studio was installed. Also, I've verified that CRM.exe is in the specified path. I've tried re-installing and repairing multiple times as well. Also tried to make sure all permissions were available. No luck so far... :(
Are you able to interrogate other applications (like Notepad or Calc)?
TCS
I am also facing the same issue on Windows 10.Any help will be highly appreciated.
What version of Pega Robotics Studio are you using? Are you able to interrogate other applications like Notepad.exe?
TCS
I am using version 8.0 .I am not able to interrogate any applications.Getting same error everytime.
I suggest you open an SR to have someone look at your issue live. There must be some security software running that is blocking Pega Robotics.
If you open an SR, please leave a reply with the SR number so that we may track for you!
TCS
ING
Just wanted to know why did you come to this solution. of formatting windows. I am facing the same issues.
Did you find any alternative way to resolve the issue?
ING
No was not able to find any other way, so downgrading to Windows 8.1
Cognizant
I was able to interrogate CRM.exe on windows 10 until yesterday ,I had a windows update and its not working now. I suspect the issue occurred after the update on windows 10! Don't we have any other option other than downgrading windows??
