InnovationTeam
SA
Last activity: 29 Oct 2025 5:28 EDT
Unable to open an instance CoexistenceCasesDT when running portal in Constellation
I am getting the below error when running portal in pega Constellation. Has anyone seen or resolved a similar issue before?
Reply
Raijmond Lassche Joost Spekschoor Mattia Rosellini -
Achmea
We get it too: any thoughts on the solution?
@BOUANENEM Can you share the PRPC version, this was fixed in latest versions
InnovationTeam
SA
@yerrs2We are using version 23.1.0 and are encountering an intermittent issue—sometimes it works, and other times it does not. If you have any insights or suggestions, they would be greatly appreciated.
The Low-Code Valley
@yerrs2which version do you mean with latest versions?
We have now 24.1.3 and having also this issue.
What i also see in the logs and when creating a case, is the error:
An internal error occurred while fetching the results using data view. Please contact administrator
I have created an empty data transform with that name and the error is gone.
@BOUANENEM This is an handled exception and will create this DT when its not present while using coexistence wizard. This should not cause any issues with your workflow. Incase if you observe any specific issues with this exception can you please specify them?
@BOUANENEMAs i have mentioned earlier, This should not cause any issues with your workflow. Is it blocking you from your workflow? I can only see you have attached a sc from tracer. Do you also observe any error in the runtime/portal? If so, can you attach that sc as well?
InnovationTeam
SA
@duddr1 thank you for your feedback. There is no error message displayed, but we are unable to run the portal as it is still loading.
@BOUANENEM Can you try skipping step 4 of pxPopulateEnvironmentInfo or setting the value of Param.case in that step to empty string and confirm whether that fixes your issue. If it didn't fix your issue and you're able to see some console errors then pls attach screenshots for the same. If there are no console errors then chances are that the issue you're facing might not be related to CoexistenceCasesDT error itself. In that case please describe your usecase in brief.
InnovationTeam
SA
@duddr1The issue persists even after skipping these steps. Upon reviewing the browser console logs and network tracer, it appears that DX APIs are not functioning correctly. I am encountering a 403 Forbidden error, with the following response { "errors": [ { "ID": "unsupported_scheme", "message": "TLS should be enabled." } ] } @duddr1 , your support on this would be greatly appreciated.
Ntt Data
Hi team,
I am also getting same error when launch portal from dev studio.
Ntt Data
@BOUANENEM This happens when token got expiry or not configuring oauth client registration rule properly. Enable set refresh token expiry checkbox in oauth client registration
@BOUANENEM Was this issue resolved??
InnovationTeam
SA
@SushmaC17467317not yet resolved.
Hi @BOUANENEM!
Were you able to try what @sairam suggested? Do you still need assistance with your reply to them "Could you please specify which OAUT2 client should be updated ?"
