Issue
On opening the web portal of Constellation application, a blank screen is displayed.
Symptoms and Impact
The following screenshot shows the console errors when the issue occurs:
Steps to reproduce
- Create a Constellation application.
- Configure the DSS ConstellationPegaStaticURL with the value: https://release.constellation.pega.com:
- Configure the Content Security Policy (CSP) of Constellation application in its application definition rule and select the option Reject and Report.
- Launch the web portal.
Root cause
This behavior is consistent with the current design of Pega code or rules.
When a website attempts to load a resource, such as a script, image or stylesheet, that is not explicitly allowed by its Content Security Policy (CSP), a CSP error occurs. This means the browser blocks the resource due to the security restrictions set by the website owner, causing an error message in the developer console.
In a Constellation application, this issue occurs when the CSP is explicitly set to Reject and Report in Application rule (as shown in the following screenshot).
In the DSS ConstellationPegaStaticURL, https://release.constellation.pega.com is being used. This URL domain is different from the platform domain. As a result, the CSP interprets the resource from the unexpected domain as a violation of its rules, leading to a CSP error.
Solution
To avoid CSP errors, perform the following steps to add the ConstellationPegaStaticURL value to the trusted URLs:
- Perform a of an OOTB CSP rule to custom ruleset and make the following changes in the CSP rule.
- In the Image-Source dialog box, select the checkbox for Self. In the Allowed Websites field, add the ConstellationPegaStaticURL value. Refer to the following image:
- In the Script-Source dialog box, select the checkbox for Self. In the Allowed Websites field, add the ConstellationPegaStaticURL value.
- In Style-Source dialog box, select the checkbox for Self. In the Allowed Websites field, add the ConstellationPegaStaticURL value.
- In Connect-Source dialog box, select the checkbox for Self. In the Allowed Websites field, add the ConstellationPegaStaticURL value.
Environment
All Pega PlatformTM versions.
References
