Atos
Last activity: 27 Feb 2022 7:56 EST
Unable to install PEGA Personal Edition 8.6 : Unable to connect DB
Hi all,
Does anyone has any solution for "Unable to connect DB" error while installing PEGA personal edition 8.6
Error:
Aug 15, 2021 12:31:11 PM org.postgresql.Driver connect
SEVERE: Connection error:
org.postgresql.util.PSQLException: Connection to localhost:5433 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
Tried Solution:
1. Added exception for different port in firewall
2. Tried multiple ports
3. removed instance or PPE and downloaded new ZIP and tried again.
Any suggestion is appriciated.
