Avanade Inc
Last activity: 11 Jan 2018 10:56 EST
Trying to install Pega personal edition
I have installed Pega but am at an impasse. I get this screen as I try to open Pega. Can anyone provide me some insight as to what the URL I am expected to provide to Pega is?
Hi Nathan,
Thanks for writing to PSC.
Kindly provide the below details:
1. Pega version installed,
2. Which app server is used,
3. URL that you hit that shows this window.
Kindly provide these details to enable us to help you further.
Gurpreet
Avanade Inc
It is the PegaRULES Process Commander Personal Edition - 7.3.1 distribution. That is the activity screen that comes up when I try to launch the application that I have installed locally. Does that help you? I appreciate the response!
Kindly share the URL that you are using to access.
It should be in this format http://<HostName>:<port>/prweb/PRServlet,
In tomcat, you can get the port number from server.xml file.
Gurpreet
I hope the Personal Edition installation document might help you to understand its usage and hope you might have followed it.
Avanade Inc
Hey gents, thanks for the help! So I just did a fresh uninstall and reinstall and it seemed to have resolved my issue. I am now running into a problem logging in. Do I not log in with my PDN credentials to use the personal edition? If not, how to I get the necessary credentials?
Hi Nathan,
I think you have to first login with - [email protected] using the password- install. Then you can create an application and then login using the credentials provided. Once you create the application, it will show you login creadentials. Hope this helps.
Rachit
Note: If you have not yet created any operators, log in to the Pega Platform instance with the operator ID [email protected] and the password install.
The above information is already specified in the above link in Starting and logging in to the Personal Edition section which i had shared Nathan.
