TCS
unable to install Pega 7 personal edition
I am unable to install PEGA 7 personnel edition & receiving following error.
[echo] Waiting for Postgres to start...
Unable to connect to database -- will retry in 1 second...
BUILD FAILED
D:\pegaGuiInstallerTemp\build.xml:156: Unable to connect to database within 15 seconds.
Total time: 40 seconds
Please suggest solution
HSBC GLT - Bradesco insurance - Scopus
BR
Hi AakarshaK
It happened w/ me too. I think because related paths. I asked to download the last version. I'm wainting releasing for me 7.2
Scotiabank
As per my other post, I stopped the application, deleted the install directory, then reinstalled the application. That worked for me.
TCS
Pls have look at my complete log, i have tried all the possibilities, but i am getting child process terminated error. Suggest a solution.
Targets:Initialization,Database Server Installation,Data Load,Configuration,PRPC Launching
Buildfile: F:\115008_PE72\.\pegaGuiInstallerTemp\build.xml
Initialization:
[echo] Beginning installation of PRPC 7.2 Personal Edition -- this process should take about 5-10 minutes ...
[mkdir] Created dir: F:\PRPCPersonalEdition
[mkdir] Created dir: F:\PRPCPersonalEdition\temp
[unzip] Expanding: F:\115008_PE72\pegaGuiInstallerTemp\PersonalEdition.zip into F:\PRPCPersonalEdition
[echo] Configuring Tomcat (Setting Java Home and Catalina Home)...
[replace] Replaced 0 occurrences in 0 files.
[replace] Replaced 1 occurrences in 1 files.
[replace] Replaced 2 occurrences in 1 files.
Database Server Installation:
[exec] The files belonging to this database system will be owned by user "KARTHEEK".
[exec] This user must also own the server process.
[exec] The database cluster will be initialized with locale "English_United States.1252".
[exec] The default database encoding has accordingly been set to "WIN1252".
[exec] The default text search configuration will be set to "english".
Initialization:
[exec] Data page checksums are disabled.
[exec] creating directory F:/PRPCPersonalEdition/pgsql/data ... ok
[exec] creating subdirectories ... ok
[exec] selecting default max_connections ... 100
[exec] selecting default shared_buffers ... 128MB
[exec] selecting dynamic shared memory implementation ... windows
[exec] creating configuration files ... ok
[exec] creating template1 database in F:/PRPCPersonalEdition/pgsql/data/base/1 ... ok
[exec] initializing pg_authid ... ok
[exec] child process was terminated by exception 0xC000001D
[exec] initdb: removing data directory "F:/PRPCPersonalEdition/pgsql/data"
[exec] initializing dependencies ...
[exec] Result: 1
BUILD FAILED
F:\115008_PE72\pegaGuiInstallerTemp\build.xml:156: Unable to connect to database within 15 seconds.
Total time: 57 seconds
Bayview Asset Management, LLC
I face the same issue, Did above solutions work for anyone?
Synechron Technology pvt ltd
I am also facing same issue , Can anyone help me regarding same?
After deleting data from "//PRPCPersonalEdition/pgsql/data " i am able to install setup
ANZ
Bits in Glass
I have also faced this issue.
To solve this issue, you can try installing the personal edition on other drive.
If you are willing to install it on the same drive, you need to delete all the registry files manually.
Here are the steps which I followed to delete the Registry files manually.
Delete installation folder.
Go to Start Menu and search for regedit and open it.
From there hit Ctrl+F to find. Search for word Pega or PRPC and if result you find is related to Pega,
delete that page. You need to repeat this untill you clear all the pages.
Once you clear all the pages, you can now install your pega Personal edition without any issues.
Please note: While deleting the pages, make sure the pages are related to Pega only, not other softwares.
