Tracking Pega Agents automatically
Need to send an automatic notification whenever an agent goes down. Need suggestions on this.
But We need a solution apart from AES..is any other way without using AES
Then in each agent activity you need to handle the exceptions and on the failure step you can call one generic activity to send the notification to the manager or sys admin. But this will not work if the server went down in between.
-Saikat
Hi
You can check below url for Agent Monitoring without using AES.
https://pdn.pega.com/support-articles/how-monitor-prpc-agent-status-using-query-or-java-api.
Venkateswarlu.
You can use the value of StepStatusGood in your agent activity and use SendEmailNotification activity for sending the message when it goes down. Also, you can add log message as well.
Thanks and Regards,
Prudhvi
