PNC Bank
Last activity: 1 Aug 2017 17:37 EDT
Tracer window is not opening from the SMA
I need to trace a requestor (Batch) and while launching the tracer windor from SMA it says "TracerURL operation has been executed successfully" but tracer did not show up.
Need advise if you face similar issue.
Ismail Hasan
Alter Domus
IE
Hope these two urls help:
https://community.pega.com/support/support-articles/not-able-open-remote-tracer-sma
https://community.pega.com/support/support-articles/opening-tracer-sma-challenges-credentials
Credera
Try working in IE, else its better to launch in another session/system
Can you check PRPC Primary URL and PRPC Diagnostic URL configuration in SMA. Sometimes wrong URL syntax results in this problem.
Coforge DPA Australia Pty Ltd
Hi, Please share the path where PRPC Primary URL and PRPC Diagnostic URL configuration are in SMA. Also where to change these values like prconfig.xml or SMA or Dynamic System Setting?
Thanks in advance.
1.Go to SMA
2.Click on Node Name
On the right side you will see both PRPC Primary URL and PRPC diagnostic URL
Thank you Pavan for screenshot. Now I am able to open Tracer after updating URL's to ip address instead of localhost.
PNC Bank
Hello Ismail ,
I hope you have tried with ipaddress instead of localhost in the Primary and PRPC diagnostic URL .
Make sure you’re not giving any load balancer url .
Can you please provide the screenshot of node information from the SMA .
Arun
PNC Bank
Alter Domus
IE
