Thread Stuck in IIF 7.3 Installation
We are trying to install IIF 7.3.1 framework on top of Pega 7.3.1. But ,we are facing thread stuck issue after few hundred commits. We are using WLS as AS and Oracle as DB server.
Any help/suggestion will be highly appreciated.
Note - Increase the value of
Error - in WLS - StuckThreadMaxTime is not a good option as we do not know the upper limit.
####<May 24, 2018 4:42:55 PM BST> <Error> <WebLogicServer> <clo01appegdev10> <UNITY_PRPC_Dev02> <[ACTIVE] ExecuteThread: '16' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1527176575388> <BEA-000337> <[STUCK] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)' has been busy for "4,931" seconds working on the request "Workmanager: default, Version: 0, Scheduled=false, Started=true, Started time: 4931559 ms
", which is more than the configured time (StuckThreadMaxTime) of "2,400" seconds in "server-failure-trigger". Stack trace:
2018-05-24 16:44:52,915 [fault (self-tuning)'] [ STANDARD] [ ] [ ] (l.context.ManagementDaemonImpl) WARN - Long running request detected for requestor HBT74KO6BPA6E2SDPUK93J387ZAOVIIKT on java thread [ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)' for approximately 1809 seconds -- requesting thread dump.
