Clear stuck mobile build in Pega 7.3
The server threw an error while building a custom mobile application (under Channels and Interfaces). The progress bar for the build process is stuck and there is no button to restart the build process. I was expecting to find a record in the pr_data_mobile_build table which I could clear in order to have an opportunity to start another build. This table seems to be empty.
Is there a different process for clearing a stuck mobile build in Pega 7.3?
Thanks for sharing it. Its always learning.
As told earlier, I don't have much idea on it. I will research more, if there is any OOTB methodology to rebuilt or this is only the available option to delete the mobile instance and recreating it again for the new build.
This link contains more about build process and other things specific to Pega 7.3. Hope you have reviewed it. There are embedded link please refer them as well.
https://community.pega.com/sites/default/files/help_v73/express/procomhelpmain.htm
And it contains, comparison about build process in different versions of Pega.
