    TCS
SE
Error while installing IIF 7.1.6 on Pega 7.1.8
We have upgraded from PRPC 6.2.1 to Pega 7.1.8 and have installed PegaCS 7.1.4
Later when installing IIFv716_Install_Bundle.jar we face below issue:
2015-10-20 11:33:11,302 [.PRPCWorkManager : 0] [  STANDARD] [                    ] [     PegaRULES:07.10] (  internal.access.DatabaseImpl) ERROR  [email protected] - Encountered problem when performing a Commit
com.pega.pegarules.pub.PRRuntimeException: Encountered database exception when committing operation <insert instance RULE-INSPROD-LINE RULE-INSPROD-LINE 10/1/2014!BOP #20141219T073337.442 GMT only if new>
    at com.pega.pegarules.data.internal.access.Committer.performOps(Committer.java:507)
    at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2653)
    at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2308)
    at com.pega.pegarules.data.internal.access.DatabaseImpl.commit(DatabaseImpl.java:2047)
    at com.pega.pegarules.deploy.internal.loaders.SaverLoader.issueCommit(SaverLoader.java:831)
    at com.pega.pegarules.deploy.internal.loaders.SaverLoader.importContents(SaverLoader.java:263)
    at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:889)
    at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:762)
    at com.pega.pegarules.deploy.internal.util.ImportImpl.importArchive(ImportImpl.java:670)
    at com.pega.pegarules.deploy.internal.util.ImportImpl.importPegaArchive(ImportImpl.java:739)
    at com.pega.pegarules.deploy.internal.archive.PegaArchiveAbstract.doImport(PegaArchiveAbstract.java:362)
    at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.pxImportArchive07_10_17(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:142)
    at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.invoke(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:84)
    at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133)
    at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110)
    at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8954)
    at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
    at com.pegarules.generated.pega_importexport_pximportexport.pxImportArchive(pega_importexport_pximportexport.java:284)
    at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.step8_circum0(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:879)
    at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.perform(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:207)
    at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
    at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
    at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572)
    at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:453)
    at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:257)
    at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:320)
    at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
    at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
    at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
    at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
    at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
    at com.pega.pegarules.session.internal.async.Agent.runBatchTask(Agent.java:815)
    at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:230)
    at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
    at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
    at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
    at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
    at sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
    at java.lang.reflect.Method.invoke(Method.java:611)
    at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
    at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
    at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
    at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
    at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
    at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
    at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
    at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
    at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
    at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:782)
    at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
    at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:159)
    at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1646)
Caused by:
com.pega.pegarules.pub.clipboard.InvalidValueException:     String was not a date "10/1/2014"
    at com.pega.pegarules.pub.util.PRDateFormat.parseAsDate(PRDateFormat.java:1425)
    at com.pega.pegarules.pub.util.PRDateFormat.parseAsDate(PRDateFormat.java:1404)
    at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.setStmtInsert(PageDatabaseMapperImpl.java:1985)
    at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.fillInStatementFromPageWithStream(PageDatabaseMapperImpl.java:1382)
    at com.pega.pegarules.data.internal.access.Saver.getStatementWithPrepValues(Saver.java:1696)
    at com.pega.pegarules.data.internal.access.Saver.insertInstance(Saver.java:1066)
    at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:880)
    at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:777)
    at com.pega.pegarules.data.internal.access.Committer.performOps(Committer.java:237)
    ... 52 more
Naveen
