Test the process flow
You are developing a case type that processes scholarship applications. Scholarship application advanced based on the standardized test of the applications. A decision shape directs the process flow.
You want to test whether the process flows correctly, but you have not fully configured the user interface so that applicants can enter their standardized test scores.
1) Use a declare expression to set a value for the standardized test score filed.
2) Use Live to set how the case process and if an error occurs.
3) Use the Clipboard tool to set a value for the standardized test score filed.
Please explain the correct answer. Thanks.
