Process Flow
how to expose flow in the application as a service
Are you looking to run the flow from external systems and want to expose as services?
If Yes, you can create a case that runs that flow and mark that flow as temporary work object (so that it won't actually create the case) and expose a service to create the case. Let us know if this helps.
no i dont want to run flow from external system.i just want to expose as a service with in the cases/application.
