Tag display name changed after v8.6.1 upgrade
Hi everyone,
Hope to see if this happens with other Clients as well?
After the upgrade from v8.5.3 to v8.6.1, the tag name on the web browser has changed to the name of the actual working session.
An example:
It used to display on the web browser as the Pega application's name. That is preferred because multiple things got opened at the same time (it is standard user behaviour. hence, the need of showing the Pega application name)
After v8.6.1 upgrade, the application name displayed has changed to the name of the actual working session e.g. the case ID: application name "Pega case management xxx" to "Case ID-1234".
Hope to share and ask what to look and check to rectify it back to display the application name instead of showing the name of the working session . Many thanks.
