CTS
Last activity: 7 Aug 2023 10:33 EDT
JMS connection to Queue Factory - null pointer exception in 8.6.1
We have upgraded JMS listeners and JMS-Connectors from Pega 7.2 to Pega 8.6.1 platform with smart investigate frameworks. After that, we are facing the below exception in the JMS connection, please suggest a solution if you'd have faced the same.
Exception : Couldn't resolve JMS connection factory object 'java:comp/env/jms/PEGAQueueConFactory' from JNDI server at , javax.naming.NamingException: Unexpected exception resolving reference [Root exception is java.lang.NullPointerException]
We have migrated from WAS-based setup to Openshift Container-based platform where Pega is running on Tomcat App server. The following configurations are defined in the context.xml file and web.xml file.
web.xml file :
<resource-ref id="PEGAQueueConFactory">
<description>PEGAQueueConFactory</description>
<res-ref-name>jms/PEGAQueueConFactory</res-ref-name>
<res-type>javax.jms.QueueConnectionFactory</res-type>
<res-auth>Container</res-auth>
<res-sharing-scope>Shareable</res-sharing-scope>
</resource-ref>
context.xml file :
web.xml file :
</resource-ref>
context.xml file :
<Resource name="jms/PEGAQueueConFactory"
auth="Container"
type="com.ibm.mq.jms.MQQueueConnectionFactory"
factory="com.ibm.mq.jms.MQQueueConnectionFactoryFactory"
description="PEGAQueueConFactory"
CCDTURL="file:///usr/local/tomcat/conf/CHL-PEGAQueueConFactory.TAB"
CNLIST="******.APPS.***(1111)"
CROPT="77777"
CRT="888888"
EXP="99999"
QMGR="Server.MQ"
Detail Exception :
WorkQueueMananger Contents
| Maintain ThreadPool size :- false
| Maximum ThreadPool size :- -1
| ThreadPool inactive timeout :- 0
| unavailable - :- com.ibm.msg.client.commonservices.CSIException: JMSCS0002
Stack trace to show the location of the FFST call
| FFST Location :- java.lang.Exception
| at com.ibm.msg.client.commonservices.trace.Trace.getCurrentPosition(Trace.java:2143)
| at com.ibm.msg.client.commonservices.trace.Trace.createFFSTString(Trace.java:2053)
| at com.ibm.msg.client.commonservices.trace.Trace.ffstInternal(Trace.java:1935)
| at com.ibm.msg.client.commonservices.trace.Trace.ffst(Trace.java:1736)
| at com.ibm.msg.client.commonservices.nls.PINLSServices.createException(PINLSServices.java:112)
| at com.ibm.msg.client.commonservices.nls.NLSServices.createException(NLSServices.java:226)
| at com.ibm.msg.client.jms.internal.JmsErrorUtils.createException(JmsErrorUtils.java:126)
| at com.ibm.msg.client.jms.internal.JmsFactoryFactoryImpl.getInstance(JmsFactoryFactoryImpl.java:168)
| at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
| at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
| at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
| at java.base/java.lang.reflect.Method.invoke(Method.java:566)
| at com.ibm.msg.client.jms.JmsFactoryFactory.getInstance(JmsFactoryFactory.java:173)
| at com.ibm.mq.jms.MQConnectionFactory.initialiseMQConnectionFactory(MQConnectionFactory.java:3218)
| at com.ibm.mq.jms.MQConnectionFactory.<init>(MQConnectionFactory.java:260)
| at com.ibm.mq.jms.MQQueueConnectionFactory.<init>(MQQueueConnectionFactory.java:72)
| at com.ibm.mq.jms.MQQueueConnectionFactoryFactory.getObjectInstance(MQQueueConnectionFactoryFactory.java:69)
| at org.apache.naming.factory.FactoryBase.getObjectInstance(FactoryBase.java:96)
| at java.naming/javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:341)
| at org.apache.naming.NamingContext.lookup(NamingContext.java:864)
| at org.apache.naming.NamingContext.lookup(NamingContext.java:158)
| at org.apache.naming.NamingContext.lookup(NamingContext.java:850)
| at org.apache.naming.NamingContext.lookup(NamingContext.java:172)
| at org.apache.naming.SelectorContext.lookup(SelectorContext.java:161)
| at java.naming/javax.naming.InitialContext.lookup(InitialContext.java:409)
| at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.initializeConnection(JMSListener.java:1035)
| at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.runPoller(JMSListener.java:760)
| at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:755)
| at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:476)
| at java.base/java.lang.Thread.run(Thread.java:829)
Product :- ProductName
Date/Time :- Fri Oct 01 16:49:42 AEST 2021
System time :- 1633070982326
Operating System :- Linux
UserID :- ***user
Java Vendor :- AdoptOpenJDK
Java Version :- 11.0.11+9
Source Class :- JmsFactoryFactory
Source Method :- getIntance(int)
ProbeID :- XI001005
Thread :- name=JMS-Thread-100 priority=5 group=main ccl=com.pega.pegarules.bootstrap.loader.PRAppLoader@2c7fff1b
Data
| connectionTypeName :- com.ibm.msg.client.wmq
| exception :- ExceptionDepth is 3
| exception :-
| | Cause:1 :- java.lang.reflect.InvocationTargetException
| | Cause:2 :- java.lang.NullPointerException
| | StackTrace:1 :- java.lang.reflect.InvocationTargetException
| | Caused by: java.lang.NullPointerException
| | at com.ibm.msg.client.jms.internal.JmsFactoryFactoryImpl.getInstance(JmsFactoryFactoryImpl.java:170)
| | ... 26 more
| | StackTrace:2 :- java.lang.NullPointerException
No Components Found
