Sprint
Last activity: 15 Jun 2020 9:37 EDT
Support for Edge Chromium
I know Pega supports both Microsoft Edge and Google Chrome. Is the new version of Edge, Edge Chromium also supported and which versions of Pega support it?
***Edited by Moderator Kayla to update Product to General; update platform capability tags***
Hi AlexM
Is there a specific reason why you ask? Currently our platform support guide does not spell it out.
Edge Chromium is not even officially released, I have reached out to the SMEs for answers. Personally I am using it on my macOS, but that does not mean much as we would have to done a lot more tests in order to support it, it is likely taking some time even if Pega decides to support that in the future.
The current plan is to test Edge Chromium for the next release (8.4). Note that this plan may change, depending upon whether issues are found.
As stated in the Platform Support Guide, Pega does not backwards-test platforms, so only the version in which the browser is tested and subsequent versions will support that browser.
Capgemini Sverige AB
SE
My customer is going to switch to Edge Chromium in Mars 2020.
Would be good to know if PEGA 8.4 will have support for Chromium then.
Currently the plan is to have 8.4 GA ready by end of Jan, note that this is subject to change along with the comment that Susan already made above. Thanks.
OCBC
SG
Any update on this? Appreciate for your response.
Hello!
We see that you have created a new post to seek resolution to your query.
Good practice!
Pallavi M | Moderator | Pega Collaboration Center
