Microsoft Edge (Chromium) support for Pega Robot Studio / Runtime 19.1
Microsoft Edge (Chromium) support in Pega Robotic Automation that you need to install the Edge plug-in using Robot Studio and the Robot Runtime Setup Wizard. Do I need to select Microsoft Edge on the Browser Extension installation screen?
Also, to update multiple users, install the plug-in using a command line installation with the INST_Edge = 1 parameter. If you omit this parameter, the Edge plug-in will not be installed. What are the conditions under which multiple users need to be updated?
Toshiki sato
