Achmea
Last activity: 22 Jan 2018 6:41 EST
Stop receiving Throttle Alert emails
Although I have deleted all email subscriptions about Trottle alerts within AES We still receive them.
How to stop receiving them?
Alert "Throttle Alerts" observed by "xxxxxxxxxx Server" for system "yyyyyyyyy" node "zzzzzzzz.aaaa.bbbb" : "Excessive number of EXCP0001 alerts received - alert has been temporarily disabled"
Best regards,
Arjan Maus
***Edited by Moderator, Maryrita: moved to Product Support from PegaBuzz***
AES considers the PEGA0044 alert (alerts throttled) to be a critical event. Since Pega7 processes exception handling through the alert processor, when there are a lot of exceptions (300 in 5 minutes by default) it triggers the PEGA0044 and AES triggers both the 'throttle' scorecard and the 'health status change' scorecard.
Best thing to do of course is to fix the exceptions. I personally feel that a healthy system should never generate exceptions, though the Connect-SOAP implementation treats all SOAP faults as exceptions, regardless of whether they are from true failures or simply a mechanism for a back-end to say "no" (btw, if this is the cause of your exceptions, it is possible to change a rule and change this behavior).
Barring making the exceptions go away consider to change the PEGA0044 threshold - the defaults are pretty low. If you read the thread, prconfig settings were posted by sriva3. I personally consider editing prconfig.xml to be a bad practice and use dynamic system settings. In my systems, we only throttle / discard alerts if you get more than 5,000 in 5 minutes [system is truly broken]
Pega-Engine
prconfig/alerts/general/maxalertcounttimeperiodminutes/default
5
Pega-Engine
prconfig/alerts/general/maxalertcountintimeperiod/default
5000
Hi, Please try following prconfig settings to tweek the number of alerts.
<env name="alerts/general/maxAlertCountInTimePeriod" value="300" />
<env name="alerts/general/maxAlertCountTimePeriodMinutes" value="30" />
Regards - Anuj
JPMorgan Chase & Company
What is the exception stack trace of EXCP0001 alert ?
Achmea
I am at this moment not interested in the EXCP0001 alerts, I can solve them. I just don't want to receive emails from AES about these alerts.
Achmea
Can't anybody be of any assistance?
Pega-Engine
5
Pega-Engine
5000
