Baxter
Last activity: 21 Feb 2017 11:46 EST
email in receivers language ?
I am trying to implement notifications in multiple languages. Where the receiver (WorkParty) gets email in preferred language.
There are two people involved in correspondence - the sender and the recipient. Therefore, using Field Values to localize the item in the language of the user who is creating the item may not be correct, as the correspondence really needs to be in the language of the person who is receiving it.
In the document here, it says "your application can respect the language preference of a party"
Question: how do I set the preferred language for a workparty so that pega picks up the localized version of corrospondence ?
PRPC version : 7.2
you need to pick up the correspondance even before your email server process it.
Otherwise, it will not be possible to show the same to receiver.
So here is my thought on how you can try implementing it.
1. Let your user pick the receiver from a drop down or pick the work party from a drop down
2. Configure a onChange refresh section activity which will set the receiver's locale in some property
3. Keep another dropdown inside a separate section for user to pick up the required correspondance template.
4. Circumstance the separate section based on the selected locale so that everytime there is a refresh, PRPC picks up the section which shows the templates that belongs to that locale.
5. Now let your user choose the required template and send the correspondance.
Please note, once your email server process the outgoing email, it is not possible to replace the contents of the correspondance. So you have to do it before the email goes out of the system.
Let me know your thought on this.
Baxter
I can do the whole thing manually (getting the receiver's locale and selecting the localized correspondence). But this is not what I am trying to accomplish.
In Pega, you can localize the entire application using a localized ruleset which holds the labels and paragraphs for every text on the screen. For example: if your application ruleset is MyApp:01-01-01 then you can create a ruleset MyApp_ja:01-01-01 which holds the japanese translation for all labels. And when user's locale is set to ja_JP, it will pick all japanese labels automatically and display this in sections.
I have created a localized version of the correspondence in MyApp_ja:01-01-01 ruleset, and I want Pega PRPC to pick that localized version when I send email using the notification feature in the Assignment Shape ( Pega 7.2 ) or the Utility Shape Send Email.
whenever a task is assigned to a workparty / worklist, the notification is sent, if approver #1 is selecting "Approve" and clicking submit, PRPC should check the locale of Approver #2 and send him localized version of correspondence. Its not practical to ask Approver #1 to:
1. Pick the receiver from dropdown
2. select the localized correspondence
3. and send email.
3. and send email.
I have checked OOTB activities which are preparing and sending emails behind the scene, but I didnt find anything which is trying to send localized correspondence. There must be some OOTB funcationality to make it work without writing everything manually, because I can see in the documentation. it says that pega respect the locale of receiving workparty. But there is no mention of how?
Hello
In that case, try this
Upon approving by approver 1, there must be one routing logic in place which route the assignment to approver 2.
You need to update the logic ( either via an activity or data transform ) to first identify the locale of the approver 2 and then choose the corresponding correspondance rule based on the locale and then send out the same.
Baxter
I am trying to find any functionality related to whats mentioned here in the below help topic.
What you need is to switch the locale of current requestor (who is sending emails) to the locale of receiver.
To achieve this you need to get locale of each receiver and set it on Thread page using setLocaleName method in PRThread class and then send email.
By above logic what you are trying to achieve is easily doable.
Let me know if this helps or you need more information :)
Baxter
rawap, this is exactly what I tried, when I switch my locale to another language, all emails I sent are picked up from that localized ruleset.
For instance, I am a japanese user, completing my task. And the next task is assigned to a user in America, but the user receives email in Japanese :D
You are correct, if I intervene in the email sending activity and update the current user's locale to receiver's locale it is possible. But its a hack, not the solution unfortunately. and most of these rules are final-internal.
When you say intervene in email sending activity, Are you using some OOTB way of sending emails. I was under assumption that you have a requirement where you are calling Utility/Activity to send email.
Could you let me know what is the exact configuration of sending email?
Email sending APIs are not always bounded by operators (Can also take comma separated emails directly and then no locale context), even though in your use case it is work parties.
Baxter
I am using the Notification section of assignment shape to send notification to assignee whenever the task is assigned.
I agree with you that I can develop this functionality in my application if I want, but its a very basic requirement for any internationalization. and my concern is:
If its mentioned in the Pega Help Document that its possible, it shouldn't require overriding the OOTB activities and hacking the email functionality. There should be a proper document about this functionality. And that's what I am trying to find. No luck so far :(
Hi Vikram,
Could you please share the pega help document where this is mentioned. It would help us to take this requirement further if it was documented and not implemented.
Baxter
The link and screenshot available in Original Post.
Hi Vikram,
Thanks for the link. This is already under discussion internally and you have made a valid point. I will keep you posted on the final outcome. Meanwhile i am hoping that you can go ahead with the suggested approach without any issues.
