EvonSys (Pvt) Ltd
LK
Last activity: 30 Jan 2017 23:30 EST
Stale Assignment Issue
There are few work objects in User's work list which are "Resolved Completed". When I open the case it diaplays below error message.
"Assignment Error - Work Item's assignment has been changed"
Unable to reproduce the issue yet.
Any idea how to fix the issue?
***Updated by moderator: Lochan to update Categories***updated SR details, tagged SR Exists***
EvonSys (Pvt) Ltd
LK
Thank you in advance.
What Pega version are you using? I would start by looking at the work object history for the objects where the issue occurred and see if there are any similarities. Then see if you can reproduce the issue by following the same path shown in the history.
FR
You shouldn't have any "Resolved Completed" work objects on a user's work list. A work list is just supposed to handle assignments for open work objects. It looks like the work object has been resolved but the assignment is remaining. This is a missed configuration, you will need a ticket on your flow to automatically remove the assignment when somebody else is closing the case.
EvonSys (Pvt) Ltd
LK
Hi Lassm,
This is an sporadic issue which we were identified in Production Env. We were not able to replcate the issue in lower environments.
Thank You!
Jayami
EvonSys (Pvt) Ltd
LK
Hi CarissaW,
Thank you for the response.
I am using PEGA 7.1.8. This is is sporadic. We were not able to replicate the issue.
Thank you!
Jayami
FR
Hi Jayami,
If this is sporadic in Production, I would check history records of broken cases. Following this approach you might be able to identify a root cause scenario.
EvonSys (Pvt) Ltd
LK
Hi Marc,
Thank you for your response. We have checked the history records, and found nothing unususal. So raised an SR for this.
Thank you!
Jayami
Hi Jayami,
Please let us know the SR number so that we could tag that to this post for effective troubleshooting.
Lochan | Community Moderator | Pegasystems Inc.
EvonSys (Pvt) Ltd
LK
SR - B9966 has been raised for this issue.
Kind Regards,
Jayami Dayarathna
Hi Jayami,
On reviewing the SR, we noted that the the issue was resolved after deselecting the writenow parameter that was used with the Obj-save method.
