ING Bank NV
Last activity: 26 Jul 2017 7:46 EDT
SQL exception while doing the Data Only upgrade
I am receiving the below error
[java] 2017-07-20 13:26:26,719 ( SQLLoaderInternal) INFO - DROP VIEW SMIN_DATA_OWNER.PCV4_ASSIGNMENTWB_SUMMARY
[java] 2017-07-20 13:26:26,733 ( SQLLoaderInternal) INFO - File: oracledate00150.sql
[java] 2017-07-20 13:26:26,734 ( SQLLoaderInternal) INFO - DROP VIEW SMIN_DATA_OWNER.PCV4_WORK_HISTORY
[java] 2017-07-20 13:26:26,744 ( SQLLoaderInternal) INFO - File: oracledate00160.sql
[java] 2017-07-20 13:26:26,745 ( SQLLoaderInternal) INFO - ALTER TABLE SMIN_DATA_OWNER.PR_INDEX_ACCESSGROUPROLES
[java] 2017-07-20 13:26:26,774 ( SQLLoaderInternal) INFO - Failed to execute SQL in file oracledate00160.sql
[java]
[java] java.sql.SQLException: ORA-01442: column to be modified to NOT NULL is already NOT NULL
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:951)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
[java]
[java]
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:195)
[java] at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:1036)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1336)
[java] at oracle.jdbc.driver.OracleStatement.executeInternal(OracleStatement.java:1916)
[java] at oracle.jdbc.driver.OracleStatement.execute(OracleStatement.java:1878)
[java] at oracle.jdbc.driver.OracleStatementWrapper.execute(OracleStatementWrapper.java:318)
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:110)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:98)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:77)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:65)
[java] 2017-07-20 13:26:26,777 ( SQLLoaderInternal) WARNING - Statement: ALTER TABLE SMIN_DATA_OWNER.pr_index_accessgrouproles MODIFY pzInsKey NOT NULL
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
[java] Exception in thread "main" com.pega.pegarules.install.SQLLoaderException: Error executing SQL statements
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:80)
[java] Caused by: java.sql.SQLException: ORA-01442: column to be modified to NOT NULL is already NOT NULL
[java]
[java] ... 1 more
BUILD FAILED
/pega_install/scripts/setupDatabase.xml:2264: The following error occurred while executing this line:
/pega_install/scripts/setupDatabase.xml:2282: Java returned: 1
Please help
Hi Sudheer,
Can you check this alter statement "ALTER TABLE SMIN_DATA_OWNER.PR_INDEX_ACCESSGROUPROLES" in oracledate00160.sql and validate the alter statement it seems one of the column is already NOT NULL and the statement is trying to alter it again to NOT NULL.
Hope this helps you to resolve the issue.
Sai Kishore
