ING Bank NV
Last activity: 4 Oct 2018 5:54 EDT
I am receiving the error table or view does not exist while performing the data only upgrade
Please find the below logs and I am recieving the below error when i performed the data only upgrade.
sample/customInfoDataPage" and owning ruleset: "Pega-Engine". PegaRULES database context is not available.
[java] 2017-07-18 15:11:34,889 [ main] [ ] [ ] (ernal.access.DataSourceManager) ERROR - Unable to obtain DataSource for sample: jdbc/PegaRULES
[java] 2017-07-18 15:11:34,897 [ main] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: /tmp/PegaInstallTemp-18-July-2017-15.09.28/pr_temp/RuleMgmt
[java] 2017-07-18 15:11:34,913 [ main] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Copy application archive [PRPC_Data.jar] to folder [file://default:/]...
[java] 2017-07-18 15:11:34,930 [ main] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Copy complete.
[java] 2017-07-18 15:11:35,184 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Expanding bundle [file://default:/PRPC_Data.jar] to [file://web:/StaticContent/global/ServiceExport/PRPC_Data]...
[java] 2017-07-18 15:11:35,220 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Bundle expanded.
[java] 2017-07-18 15:11:35,228 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - ***** Begin Application Definition *****
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Name: PegaRULES ProcessCommander V07
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Description: PRPC RuleBase
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Application Steps:
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - 1: Data_All_07.10.01.zip
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Type: PARFILE
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Bootstrap Only: false
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Install Only: false
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Step Compile: true
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Clear First: false
[java] 2017-07-18 15:11:35,229 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - ****** End Application Definition ******
[java] 2017-07-18 15:11:35,257 [ main] [ ] [ ] (hive.importer.AppBundleHandler) INFO - Started import of Data_All_07.10.01.zip (1 of 1)
[java] 2017-07-18 15:11:35,258 [ main] [ ] [ ] (y.internal.PRRuleMgmtUtilsImpl) INFO - Data_All_07.10.01.zip is v6 Archive
[java] 2017-07-18 15:11:35,495 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
[java] 2017-07-18 15:11:35,498 [ main] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
[java] 2017-07-18 15:11:35,498 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
[java] 2017-07-18 15:11:35,508 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 22 class group definitions
[java] 2017-07-18 15:11:35,566 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
[java] 2017-07-18 15:11:40,855 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 5900 class definitions
[java] 2017-07-18 15:11:42,073 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: Oracle
[java] 2017-07-18 15:11:42,073 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production
[java] With the Automatic Storage Management option
[java] 2017-07-18 15:11:42,073 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: Oracle JDBC driver
[java] 2017-07-18 15:11:42,074 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: 11.2.0.4.0
[java] 2017-07-18 15:11:42,074 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 11.2
[java] Jul 18, 2017 3:11:42 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.PRException: PRException
[java] From: (unknown)
[java] at com.pega.pegarules.deploy.internal.archive.importer.synchronization.AppBundleSynchronizer.performSynchronization(AppBundleSynchronizer.java:75)
[java] at com.pega.pegarules.deploy.internal.archive.importer.ArchiveImporterAbstract.importArchive(ArchiveImporterAbstract.java:45)
[java] at com.pega.pegarules.deploy.internal.archive.importer.DataUpgrader.handleArchive(DataUpgrader.java:60)
[java] at com.pega.pegarules.deploy.internal.archive.importer.AppBundleHandler.deploy(AppBundleHandler.java:90)
[java] at com.pega.pegarules.deploy.internal.archive.importer.DataUpgrader.runUpgrade(DataUpgrader.java:66)
[java] at com.pega.pegarules.deploy.external.util.UpgradeUtil.main(UpgradeUtil.java:75)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:498)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.database.DatabaseException: Database-General ORA-00942: table or view does not exist
[java] 942 42000 ORA-00942: table or view does not exist
[java]
[java] DatabaseException caused by prior exception: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
[java] | SQL Code: 942 | SQL State: 42000
[java]
[java] Caused by SQL Problems.
[java] Problem #1, SQLState 42000, Error code 942: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
[java] at com.pega.pegarules.deploy.internal.archive.importer.ImporterDataModelImpl.getResultSetIteratorForClass(ImporterDataModelImpl.java:181)
[java] at com.pega.pegarules.deploy.internal.archive.importer.synchronization.UpgradeRulesSynchronizer.getIterator(UpgradeRulesSynchronizer.java:165)
[java] at com.pega.pegarules.deploy.internal.archive.importer.synchronization.AppBundleSynchronizer.synchOnClass(AppBundleSynchronizer.java:82)
[java] at com.pega.pegarules.deploy.internal.archive.importer.synchronization.AppBundleSynchronizer.performSynchronization(AppBundleSynchronizer.java:72)
[java] ... 14 more
[java] Caused by: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:951)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:208)
[java] at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:886)
[java] at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1175)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1296)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3613)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3657)
[java] at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1495)
[java] at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.executeQuery(DatabasePreparedStatementImpl.java:395)
[java] at com.pega.pegarules.deploy.internal.archive.importer.ImporterDataModelImpl.getResultSetIteratorForClass(ImporterDataModelImpl.java:173)
[java] ... 17 more
[java]
[java] Jul 18, 2017 3:11:42 PM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java]
[java]
[java]
[java]
[java] ... 14 more
[java]
[java] ... 17 more
[java]
[java] Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:279)
[java] Caused by: com.pega.pegarules.pub.PRException: PRException
[java] ... 1 more
[java]
[java]
[java]
[java]
[java] ... 14 more
[java]
[java] ... 17 more
[java] 2017-07-18 15:11:42,373 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 0 for database "pegarules" to the pool as it previously encountered the following error
[java] User ID: (unknown)
[java] Last SQL: SELECT pzInsKey AS "pzInsKey", pxObjClass AS "pxObjClass" FROM SMIN_DATA_OWNER.pr_data_dms_customer_data WHERE pxObjClass = 'DMOrg-DMSample-Data-Customer'
[java] java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
***Edited by Moderator: Marissa to add SR Details***
